Joe Mckamey
Member
I’m looking for some advice on an electrical issue we’re chasing in a newly acquired RV-12iS.
Summary of the problem:
We’re seeing battery discharge indications associated with lighting loads, along with a slow, progressive degradation in the system’s ability to charge the battery in flight. The behavior is intermittent and inconsistent — occasionally everything looks normal, even with lights on — but the overall trend since purchase has been steadily downward.
Aircraft background / timeline:
We have now flown the aircraft approximately 120 hours in the two months since purchase
The night before we picked up the airplane, an issue was being troubleshot where the flap position indicator was not displaying on the G3X. SteinAir was consulted, and wiring work was performed behind the avionics panel during that diagnosis and fix.
Based on the log data and our operational experience, it appears that something may have changed during that troubleshooting, as the battery has never charged the same during flight since that time.
Avionics configuration:
As a general note, the aircraft is equipped with:
Dual Garmin G3X and a Garmin 175
Current symptoms:
The battery discharge behavior is inconsistent and load-dependent, but not in a predictable way
We had the airplane inspected by a Rotax-certified shop here in Glendale, AZ. They confirmed that everything on the Rotax side, forward of the firewall, is operating as it should, including the charging system components. Based on their assessment, the issue does not appear to be forward of the firewall.
At this point we’re trying to determine whether this is most likely:
An airframe-side charging or distribution issue (wiring, grounds, connectors, fuse blocks, HIC connections, etc.)
A voltage drop or reference issue introduced during avionics wiring work
A poor ground, loose connector, or pin tension problem
Or a known RV-12iS electrical weak point
If anyone has seen similar symptoms or has suggestions on where to start troubleshooting, I’d really appreciate the insight. Specific checks, known failure points, or voltage/current numbers to verify would all be helpful.
Thanks in advance. I used AI to help me craft this post. Hopefully it doesn’t come through too robotic.
Joe
- Reviewing the aircraft logs, the recorded in-flight battery voltage was consistently 14.0–14.1 volts right up until the day we picked up the airplane
- When we first began flying it, we were typically seeing 13.8–13.9 volts in flight
- Over time this has continued to decline, and we are now typically seeing about 13.3 volts in cruise
Current symptoms:
- Sometimes we can run all exterior lights with no battery discharge indication
- Other times, running only the strobes will produce a battery discharge indication
- When a discharge occurs, it does not always correlate with total electrical load
- Even during flights where the system appears to be charging normally, the battery never seems to recover fully
- After landing, we use an Optimate 275 charger, which brings the battery up to about 14.1 volts, and the charger indicates the battery itself is healthy
- The issue is intermittent, with occasional portions of flights where everything appears normal
Joe
