bluskydreamin
Active Member
I’m fitting the main pants and trying to follow the plans. The plans top gap spacer of 1.25” results in the bottom of my pants not even covering the lower hub curve and brake disc.
If I use a .75 top spacer I can get the hub covered but still have 4” of tire hanging down below the pant and the opening isn’t relief trimmed yet.
Wouldn’t want to go shorter than .75 on the top spacer.
Using air hawk 6-6 mains inflated to 42psi.
Is it possible that I was sent -14 main pants or is there even a difference between them? No part numbers on these pants. They are 37.75” long. Would someone please measure the length of your -10 main pants? Thanks!
Wouldn’t want to go shorter than .75 on the top spacer.Using air hawk 6-6 mains inflated to 42psi.
