This is what the inside of the turbo muff looks like. They include a restrictor (under the green tape) if you need to slow down the airflow.
You can step drill the restrictor open if you need more airflow.
They’ll make a muff for your exhaust diameter and set it up per your instructions if you need inlets and outlets pointing in different directions.
Heat muffs are simple air to air heat exchangers. The HOT part is the exhaust pipe with the hot air. Those extra tubes are not connected directly to the pipe. They will increase the heat transfer from the MUFF to the air, but the main HOT PART is the exhaust pipe not the muff.
Really no telling how well this fancy Aircraft Spruce one works. It will work but its it worth the primum price they no doubt charge. I will say the welding is top notch.
I had Aircraft Exhaust make my 4 into 1 pipes. They welded heat studs to half the pipe. This will be most effective getting heat transfer from exhaust pipe to air.
Heat muffs are made to be simple, light, compact and good enough. As I posted above there are so many things that makes the cockpit cold and drafty in winter. Big fan of an cockpit air exhaust/vent in low pressure part of the plane in the aft section to draw air in from the heat muff. Leaks that pressurize the cockpit can fight the heat muff. With that said how cold is it? Can you wear warm clothes? gloves, heated suit (have one for winter motorcycle riding.
