kentlik
Yes I have the Nova 4000 rpm, think I got it from Cleaveland. It's not a keyless chuck though, I would be very curious to try one tho because having to deal with the chuck all the time is a real drag!
Kent what do you mean inside? I just want to point out that if it's inside the cabin (aka on top of the 772 forward bottom skin) that would be a big big no no. Dan H has pointed out that this stuff smokes a lot when heated up and you certainly don't want that in cabin. I think however you probably meant under the skin but on top of the new skin and I just didn't understand properly.![]()
I guess you are correct on that I thought I read and reread all that but I was going to put it sandwiched between the forward bottom skin with an additional skin over that, not per plans. I am buying about 0.50 or so to get my size 6 feet up on the pedals a little more.
I watched all his tests and didn't think this one burned ie. smoked...
