RV-14 Rudder Pedal Blocks
TASEsq
Patron
Impressed by the quality of some aluminium products out there, but not liking the cost (espcially with foreign conversion / postage issues / tariffs etc!), i decided to design and 3D print some of my own.
Thought i would share here in case anyone else wants them.
They can be downloaded here.
They are printing at the moment - the photos of the real world ones were of V1 of the design but give you an idea of the fit.
To get a whole set you would need to print:
- 2 x Top Left blocks
- 2 x Top Right Blocks
- 4 x bottom Blocks.
They bolt togehter with 10-32 x 3/4" Cap head Screws and AN365-1032A captive nyloc nuts.
Will post a photo once ours are done on the printer.
They fit great! Nice work
Just a test fit while i wait for hardware, but its a perfect fit. They do look close, but there is no interfearance with the brake pedals.
A small update - i finally got mine printed and installed.
I initially used some High Temp resin in my Dad's resin printer, but this was too brittle. They cracked as soon as i tried to torque up the screws.
Instead i had them done in Nylon using SLS over at JLC3DP.
I reckon they came out great!
Here is the write up.
Just be sure they can't rotate and jam the brakes. I designed and grew similar pedal blocks but extended a tab over to the vertical part of the frame so there was no way they could rotate. See the picture - ignore the gust lock.
