It's been about five years since I changed tires and tubes. I've always used Condor tires and Michelin Air Stop tubes. When I opened the box for the Air Stop tube I saw a clear bag attached to it with the hardware shown below. I don't recall receiving this the last time I changed tubes. Am I right in guessing that this is meant to act as the hold off hardware for the valve stem, i.e. a nut behind the wheel rim on the inside, and then the larger retainer piece followed by the other nut on the outside of the wheel rim?
[/IMG]
My Cleveland Wheels have a rubber grommet that acts as the valve stem holder so I don't see the need for the Michelin hardware, but I'm willing to learn a new trick. (Both tubes included the hardware so it's not a fluke.) Perhaps non-Cleveland wheels need this, I don't know.
BTW, if you get frustrated with trying to push the valve stem through the rubber grommet, I found a useful trick (frustration is the real mother of invention). After pushing the valve stem through the grommet so that a little bit of thread shows, you can use one of the supplied Michelin nuts and thread it onto the valve stem. Then use a socket wrench (7/16" as I recall) and wrench away. The valve stem will be pulled through without additional cursing on your part.
Chris
Chris
