I am looking for recommendations for some "touch-up" primer. One of my surfaces (factory built) in the tail section has some of the greenish primer that has flacked off. It's a small area, so I need a very small quantity. Ideally that would closely match the green primer that Van's uses. It is behind the tail cone cover, so it is not visible from the outside. A rattle can type would work, if avaialble since I don't have paint equipment.
Thanks in Advance!
HARRY
Thanks in Advance!
HARRY
