Looking for info on grounding dual pmags on a new io-540. Emag manual said it should be grounded to the panel ground whereas general community says it should be to the engine case. Others say both. I understand the engine case would keep it always running if you lost ground from the neutral bus. Questions:
1. Is there a case for grounding to both and why?
2. If you ground to both should it be two separate splices on to the pmag harness to share the same splice?
