Getting the lower cowling off/on on my -7 with a 3 blade prop is a real pain. Not so bad for the condition inspection when there is more engine work to do/check but irritating when just doing a 25 hour oil change.
Anyone implemented a clever solution for lower oil drain plug access (0-360), I have the quick release spring loaded oil drain plug installed.
Figs
Figs
