gmcjetpilot
So these things are popping up on TV. I have heard others use these medical devices, they are fairly light, compact and run on 12 volts DC internal or external power.
Anyone use these. What does the FAA say about using these to meet FAR 91.211 Supplemental oxygen. They are FAA approved for passengers on airlines. The most compact sized portable units produce 630 to 1250 ml/min O2. Some produce 3L or more. I assume current draw and size of unit is proportional to O2 output.
They extract the ambient O2 available and concentrate it. They weigh 3 to 6 lbs, depending on output desired. The size is well under that of a small O2 bottle. I called one company and they say they can make their spec output up to 10,000 feet. They run time on battery alone was 5 hours, but at higher output (as you might need at higher altitudes) is 2 hours. With 12 volt cable it can run indefinitely.
