O-360, CS, RV6A, 1400 hours. Last two flights the CHT on number 4 cylinder started running 20 degrees hotter than ever before. EGT is a little hotter. I switched the probes from 2 to 4 and I don’t think it’s the probe. Replaced intake gasket and connection pipe. Compression check cold 75/80, bore scope looks good. 1 mag and one E-Mag, mag check is good. What have I overlooked?
