az_gila
#1 These airplanes and pilots are "tested" quite a bit before competition, but are by their very nature, on the edge. Nobody would watch a bunch of "perfectly safe" 172's dicing for position on the course
#2 The "public" are there willingly. They put themselves in harms way with eyes wide open.
For #1 - it appears from the reports that the crash P-51 was picked up from the modifier just before Reno, and had never flown that fast before.
I realize the bit about "on the edge" but F1 race cars get proven and tested in private.
If these planes are Experimental how do they get around the Phase I testing bit? Does Reno count as a Phase I test area during the races?
It sounds like the FAA could easily require more testing under the "Experimental - Racing" certificate after major changes -
http://www.faa-aircraft-certification.com/experimental-flight-test.html
New Program Letters (http://www.faa-aircraft-certification.com/support-files/sample-program-letter.pdf) seem to be needed after any major change.
I hope this is implemented...
