Folks, this is a matter of perception. Is such an act necessary under normal arrival procedures? I will submit that it is not. It really doesn't matter if it is legal or not.
Point being that the Cessna 182's or Cherokee's don't do such passes.
I remember, Paul. I also think that the negative threads of the past week or two have overshadowed the positive ones - the ones that SHOULD be receiving the most attention (first flight announcements, for example.) I suppose you're right that the moderators can't fix everything, and as the forum base continues to grow, we will likely see an increasing amount of the undesirable types of posts that you mentioned. As for threads specific to pilot behavior, I think it's important to note that EVERY topic (low passes, overhead breaks, formation in the pattern, low-level acro, radio etiquette, etc...) has already been beaten to death several times over (probably within the past year alone), and I, for one, see no point in even allowing them pop up again and again. It seems a bit ironic that when someone does ask a specific RV-related build question there is often an immediate reply of "use the search function." Yet when a topic like this comes up that involves emotion/opinion, it is allowed to fester to the point that it predictably degrades to the extent where it becomes an ugly exchange of personal attacks and must be locked....after five or six pages of a slow decline. My two cents? Nip them in the bud early and (maybe) post a link to a previous thread of the same topic.....or just send them to the "red" board at AOPA where such dialogue seems to be the norm.Does anyone remember the days when you could come to VAF and read respectfully submitted opinions, clearly stated facts, and honest, open discussions - without all the emotions, all the **** (which means that you can't think of a decent word), and all of the clearly "oh yeah, who's going to make me!!" bullying behavior?
I liked that - it was what set this place apart. We have now had a solid week of threads which has done nothing but divide us. We have posters with only a few posts (and no name in their profile, or signature in their posts) making broad acrimonious statements. Every thread other than one asking a specific building question devolves into an argument about behavior.
And no folks, the Moderators can't fix it without being called out as draconian.
If you want VAF to become a swamp, then keep it up. One thing I am absolutely certain of - you are not going to change a person's mind by arguing with them on the internet. You just poison the atmosphere for everyone.
(If you HAVE to post yet another vote for or against the Overhead break, why not do it over on that thread. This thread is about low passes!)
Is a mid field crossing 500' above the traffic pattern...then at some point on the downwind side of the field tear drop entry into a 45 degree entry acceptable?
Yes, except that sometimes they have waivers to exceed speed limits. For instance the T-38 is waivered to 300kias below 10kft. In general, military aircraft are subject to all the same rules that civilian aircraft are when operating anywhere in the NAS.
I have been flying a fair number of years and have never heard the term "pull closed" in any civilian aviation manual, magazine, AIM, etc. Have I been missing out on some important terminology utilized when landing at an airport??
The above comments were made by dabney. The links below I copied from Mr Radtke's post on another thread
http://www.aopa.org/members/files/pi...08/pc0810.html
http://www.aopa.org/members/files/pi...08/pc0804.html
http://www.aopa.org/members/files/pi...ch/pc0903.html
Jeff Radtke
Lake Geneva, WI
RV-7A
Perception is reality.
Even an SH-60 (Ken!) can look cool with a well done fly-by, .
Doesn't everyone's instructor teach this???I do this all the time but usually 1000' above the pattern. The turn back to the downwind can be timed to blend in nicely with existing traffic. I don't believe there is anything wrong with this and maybe a topic for another thread?
I have done plenty of fast low passes in our RV7, however it has been done as a missed approach with the appropriate calls being made, an approach to say 50' followed by a short portion level and then climb away
(both UK posters)... I am sure you both appreciate that the "low approach and GA", if intended, can only break the 500' criteria if 'it is flying in accordance with normal aviation practice for the purpose of taking off from, landing' and is operating from a Licensed Airfield. You cannot break the 500' criteria for a planned Go-Around at an unlicensed airfield.Of course, you can dress it up as a low appproach and go-around.........
Here's an interesting passage from an article pubilshed in FAA Aviation News:
"Proper assessment of the runway condition, when making a land/no-land decision, is the most critical skill for any pilot learning to land on grass. A pilot should learn to make a low pass over a grass runway to assess its condition prior to making this decision."
Full article: http://www.faa.gov/news/aviation_news/2009/media/JulAug2009-GrassIsAGas.pdf
And..... is the assessment actually easier at 200kts than at 100kts?
You should be impressed......at the level of moron-ness.(new word!)
We have a situation here in central Florida in one of our aviation communities where there is one individual who apparently takes great pleasure in turning folks into the FAA for certain activities at his home field.
What airport is it?
Sec. 91.119 ? Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
I would have serious reservations about a forum moderator or leader deleting a thread simply because it may not look favorable upon the group. The topics brought up are very serious, self-critiquing in nature, and are intended to help the group prevent, or at least consider, flying behavior that may or may not be looked upon highly by our fellow aviators.
It's been kind of hinted at, but not really spelled out here, so I'm posting this just for the reference (plus a little editorial comment after). My understanding is that aside from the "careless and reckless", the other low pass violation is for 91.119 (para (b) and (d) omitted):
It's pretty hard to abide by 91.119(a) at 100' and 200 kts if your engine fails. Vref, and maybe you can put it down by the end of the runway.
I've heard that the low pass suggested by the authorities to assess the landing surface is part of the "Except when necessary for takeoff or landing."
Not sure about the case law or precedent, but if I were standing in front of the judge, it'd be a lot easier to say I was evaluating the landing surface at a speed of Vref than from 200 kts.
Hope I' not just piling on.
I'm with you on evaluating the runway at a lower speed. It helps to see.
However, if you are going to fly 100 AGL, the faster you go the more kinetic energy you have, which enhances your ability to complete "an emergency landing without undue hazard to persons or property on the surface."
The oldest flying pilot I know told me once, "You can fly low and you can fly slow, but you don't want to fly low and slow"
Prior posted links have proven that the FAA can "get you" if they want to... So rather than worrying about what can happen at a potential hearing in the future, fly safely and let the chips fall where they may.
That is my philosophy anyway.
Hans
Big brother and the local news stations are watching all of us. A few inmature folks can screw all of us with their "watch me" actions. All of us lucky enough to fly RV's should just be thankful for what we get to fly and enjoy them in a sain way. Our "FAA friends" can make our lives not so good. Their job is NOT to promote aviation but to "protect the public". Think about that for awhile. If you doubt this sit back and watch what happens after the dust settles out in Reno this year.
Their [FAA's] job is NOT to promote aviation but to "protect the public".
...I can see some new limitations, as seen at airshows after numerous tragedies threatened them......more separation of spectators from the flight line, course modification to further reduce energy directed at the crowd ,etc. etc.
How about better testing of the race planes before they are allowed to race in public?
