New Lycoming AD for connecting rod assemblies
The NPRM was prompted by several reports of connecting rod failures, which resulted in uncontained engine failure and IFSDs, and a manufacturer investigation where it was determined that affected connecting rod small end bushings may be installed on additional populations of Lycoming engines. The manufacturer also determined that degradation of the connecting rod small end bushings is detectable during oil change inspections. In the NPRM, the FAA proposed to require repetitive oil inspections for bronze metal particulates and, if found, additional inspections of the connecting rod bushings for damage.
I guess this mandates analysis of the oil specifically for bronze. It does not specify the part numbers of the affected connecting rod small end bushings, but does terminate the AD if you replace them.
I guess you could swap the connecting rod small end bushings without splitting the case
I got it too.
Can someone explain what the "Y" in front of YIO-360-M1B means?
That's what my engine model says, but I cannot find that variant on the list.
Does it apply to my engine or not?
P/NAffected partShip date range
LW-13923Connecting Rod Bushing01/30/2009-11/17/2015
LW-11750Connecting Rod Assembly01/30/2009-11/19/2015
78030Connecting Rod Assembly01/30/2009-03/31/2016
LW-19332Connecting Rod Assembly01/30/2009-01/03/2016
LW-13865Connecting Rod Assembly01/30/2009-02/14/2017
77450Connecting Rod Assembly01/30/2009-02/14/2017
LW-13422Connecting Rod Assembly01/30/2009-02/14/2017
LW-13937Connecting Rod Assembly01/30/2009-02/14/2017
LW-15288Connecting Rod Assembly01/30/2009-02/14/2017
Table 1 to Paragraph ( c )—Affected P/Ns
I got it too.
Similar to "X" means it was sold as Experimental, or to an Experimental builder/owner.
Pretty sure the answer is "yes".
Also, the rule does not mandate oil analysis for bronze. Only visual inspection of the oil filters and screen.
I got it too.
Larry, you bought that engine from Van's right? IIRC, the "Y" is Van's company designation for "experimental" working with Lycoming.
Sort of yes. I actually bought it from someone who bought it from Vans.
Thanks. That makes sense. I will add the AD to my manual and checklists.
The new AD references Lycoming Mandatory Service Bulletin No. 630A, dated June 13, 2017 however they do NOT reference Lycoming Mandatory Service Bulletin No. 632B, dated August 04, 2017 (WHY ?) which gives much more info on the issue, shows a special tool inspection/replacement and gives a definitive engine s/n table.
Appears to me the FAA is casting a very wide range of engines here... Just an observation.
Here's a phrase that could use more precision:
If, during any inspection required by paragraph (g)(1) of this AD, any bronze metal particulates are found and the source is identified as the connecting rod bushings, before further flight, inspect all affected connecting rod bushings
ANY particles or particulates? Of any size? So a single tiny, barely-visible particle? What does this phrase mean, if anything? I'd expect more definite specs here.
And if one does find a particulate or two, how can you identify it as coming from the rod bushings? Aren't there other bronze parts in the engine (I *thought* so, but I'm not an engine building expert, others could chime in here)? Or are the only bronze parts the rod end bushings?
I’m gonna rely on my oil analysis as the primary indicator backed up by visual on the filter and screen, which is what I do anyway on all of my oil changes. I start to see a spike then I’m gonna call Barrett and get further advice.
Oil analysis is not a substitute for cutting open and visually inspecting the oil filter and inspecting the sump "finger strainer". Gross failures produce particles too large to show up in the spectrographic oil analysis results!
Skylor
Skylor
Never said it was. However I also believe in using all the tools available. It’s quite possible there will be a precursor rise in copper and tin before visible particles are present. IMO if you wait until you see particles that large you are danger close to a catastrophic failure. That said oil analysis is not a panacea but I think it’s an important part of a holistic approach to engine maintenance.
What I didn't get from any of the text was: what is the root cause of these failures? What's different about these bushings or their installation, or the rods, or something, that caused the failures they observed? Metallurgy? Dimensioning? Assembly method? Operations?
These are the rod P/Ns not the bushing part numbers he was asking about
One can only assume theses are OEM Lycoming small end bushings shipped with the above rods and applicable dates
It appears from SBs that it's non-conforming small end bushings that are coming loose and working their way out and causing failures. My guess is it's a tolerance issue causing too loose a fit
Lycoming MSB 480F explains the limits and corrective action for bronze particles...size and quantity
Like so many other companies , a clear lack of quality control exists at Lycoming.
QA departments don’t add anything to the bottom line, they are a requirement to do business, generally considered a cost burden to manufacturers.
The recent (last 10-15 years) has been to “design in” quality (one time cost) and not inspect for quality (re-occurring cost). I have always thought this would end up bitting you in the end.
Poor quality most often has a huge effect on bottom line as it will certainly show itself eventually in sales, reputation, and possibly liability. The current daily aviation news cycle is proving that out for at least one aviation company.
Don't get too spun up. Not to overstate the obvious, but we should be inspecting filters and screens for metals at every oil change anyway. For an individual maintaining his own, as most of us are, the compliance requirements are not a big deal.
That said, if you are selling your airplane, do not change the oil and filter. However good your intentions may be, it generates a red flag discussion between the purchaser and his pre-purchase mechanic.
What happens when you need to change your oil and filter? Like if you fly your plane?
So in other words you cannot fly your plane once the oil times out?
If a sale is eminent, why not save the media and post inspection remnants to show a potential new owners mechanic.
Or, state you did the inspection and found nothing, which should be logged anyway.
If your engine was overhauled prior to 2009 then this AD is N/A by date. On the flip side be careful saying N/A by date if it was overhauled after 2016 as parts may still be in inventory for years past the last ship date.
Chris, it's your choice. I'm just sayin' a seller is not always doing himself a favor by presenting an airplane with a fresh oil and filter.
Makes sense.
However, if I was selling an airplane I was flying and it needed an oil change it would get it. If by chance a prospective buyer showed up right after, and became uncomfortable that they couldn’t directly check it themselves, I would tell them “this airplane isn’t for you”, and move on.
Just got notification from the FAA:
In a prior thread, a poster was inquiring about Titan engines, which may have Lycoming parts with similar connecting rod numbers to those in the AD. My Titan IO-370 lists the connecting rod number as AEL 11750-S; the Lycoming AD part number is LW 11750. I emailed JB at Titan to get a clarification and the following is his response as of today..."The AEL 11750-S rods are not affected by the AD that affects certain Lycoming connecting rods that are part number LW 11750. The Continental rod bushing number is AEL 13923. Continental AEL 11750-S connecting rods and bushings are manufactured by Continental, not Lycoming, have different part numbers, and therefore not affected."
I assume that this clarifies the AD as it relates to Titan engines. Steve
Do you have JB's current email? Tks Barry
I got an email from JB "No Lycoming connecting rods have ever been used in Titan engines." ; so this AD does not apply to Titan Engines. Cheers Barry
Well that is a relief! I am flying behind a Titan IO360 with close to 1200 relatively trouble-free hours. That said, I cut the filter and check the strainer at every oil filter change.
Note...when Blackstone (and any other spectro analysis lab) says "microscopic", they are talking about particles less than 15 microns in size. The industry generally considers 10 microns as the upper detection limit for ICP spectro, unless larger particles are first dissolved with an acid procedure.
