Auburntsts
Just got notification from the FAA:
drs.faa.gov
It does not specify the part numbers of the affected connecting rod small end bushings
| P/N | Affected part | Ship date range |
| LW-13923 | Connecting Rod Bushing | 01/30/2009-11/17/2015 |
| LW-11750 | Connecting Rod Assembly | 01/30/2009-11/19/2015 |
| 78030 | Connecting Rod Assembly | 01/30/2009-03/31/2016 |
| LW-19332 | Connecting Rod Assembly | 01/30/2009-01/03/2016 |
| LW-13865 | Connecting Rod Assembly | 01/30/2009-02/14/2017 |
| 77450 | Connecting Rod Assembly | 01/30/2009-02/14/2017 |
| LW-13422 | Connecting Rod Assembly | 01/30/2009-02/14/2017 |
| LW-13937 | Connecting Rod Assembly | 01/30/2009-02/14/2017 |
| LW-15288 | Connecting Rod Assembly | 01/30/2009-02/14/2017 |
Similar to "X" means it was sold as Experimental, or to an Experimental builder/owner.I got it too.
Can someone explain what the "Y" in front of YIO-360-M1B means?
That's what my engine model says, but I cannot find that variant on the list.
Does it apply to my engine or not?
Also, the rule does not mandate oil analysis for bronze. Only visual inspection of the oil filters and screen.
P/N Affected part Ship date range LW-13923 Connecting Rod Bushing 01/30/2009-11/17/2015 LW-11750 Connecting Rod Assembly 01/30/2009-11/19/2015 78030 Connecting Rod Assembly 01/30/2009-03/31/2016 LW-19332 Connecting Rod Assembly 01/30/2009-01/03/2016 LW-13865 Connecting Rod Assembly 01/30/2009-02/14/2017 77450 Connecting Rod Assembly 01/30/2009-02/14/2017 LW-13422 Connecting Rod Assembly 01/30/2009-02/14/2017 LW-13937 Connecting Rod Assembly 01/30/2009-02/14/2017 LW-15288 Connecting Rod Assembly 01/30/2009-02/14/2017
Table 1 to Paragraph ( c )—Affected P/Ns
Larry, you bought that engine from Van's right? IIRC, the "Y" is Van's company designation for "experimental" working with Lycoming.I got it too.
Sort of yes. I actually bought it from someone who bought it from Vans.Larry, you bought that engine from Van's right? IIRC, the "Y" is Van's company designation for "experimental" working with Lycoming.
The new AD references Lycoming Mandatory Service Bulletin No. 630A, dated June 13, 2017 however they do NOT reference Lycoming Mandatory Service Bulletin No. 632B, dated August 04, 2017 (WHY ?) which gives much more info on the issue, shows a special tool inspection/replacement and gives a definitive engine s/n table.Sort of yes. I actually bought it from someone who bought it from Vans.
Thanks. That makes sense. I will add the AD to my manual and checklists.
ANY particles or particulates? Of any size? So a single tiny, barely-visible particle? What does this phrase mean, if anything? I'd expect more definite specs here.If, during any inspection required by paragraph (g)(1) of this AD, any bronze metal particulates are found and the source is identified as the connecting rod bushings, before further flight, inspect all affected connecting rod bushings
I’m gonna rely on my oil analysis as the primary indicator backed up by visual on the filter and screen, which is what I do anyway on all of my oil changes. I start to see a spike then I’m gonna call Barrett and get further advice.Here's a phrase that could use more precision:
And if one does find a particulate or two, how can you identify it as coming from the rod bushings? Aren't there other bronze parts in the engine (I *thought* so, but I'm not an engine building expert, others could chime in here)? Or are the only bronze parts the rod end bushings?
Oil analysis is not a substitute for cutting open and visually inspecting the oil filter and inspecting the sump "finger strainer". Gross failures produce particles too large to show up in the spectrographic oil analysis results!I’m gonna rely on my oil analysis as the primary indicator backed up by visual on the filter and screen, which is what I do anyway on all of my oil changes. I start to see a spike then I’m gonna call Barrett and get further advice.
Never said it was. However I also believe in using all the tools available. It’s quite possible there will be a precursor rise in copper and tin before visible particles are present. IMO if you wait until you see particles that large you are danger close to a catastrophic failure. That said oil analysis is not a panacea but I think it’s an important part of a holistic approach to engine maintenance.Oil analysis is not a substitute for cutting open and visually inspecting the oil filter and inspecting the sump "finger strainer". Gross failures produce particles too large to show up in the spectrographic oil analysis results!
Skylor
Anything caught in the finger strainer will be big enough to have a part number…lolOil analysis is not a substitute for cutting open and visually inspecting the oil filter and inspecting the sump "finger strainer". Gross failures produce particles too large to show up in the spectrographic oil analysis results!
Skylor
These are the rod P/Ns not the bushing part numbers he was asking about
It appears from SBs that it's non-conforming small end bushings that are coming loose and working their way out and causing failures. My guess is it's a tolerance issue causing too loose a fitWhat I didn't get from any of the text was: what is the root cause of these failures? What's different about these bushings or their installation, or the rods, or something, that caused the failures they observed? Metallurgy? Dimensioning? Assembly method? Operations?
Lycoming MSB 480F explains the limits and corrective action for bronze particles...size and quantityHere's a phrase that could use more precision:
The recent (last 10-15 years) has been to “design in” quality (one time cost) and not inspect for quality (re-occurring cost). I have always thought this would end up bitting you in the end.Like so many other companies , a clear lack of quality control exists at Lycoming.
QA departments don’t add anything to the bottom line, they are a requirement to do business, generally considered a cost burden to manufacturers.
What happens when you need to change your oil and filter? Like if you fly your plane?Don't get too spun up. Not to overstate the obvious, but we should be inspecting filters and screens for metals at every oil change anyway. For an individual maintaining his own, as most of us are, the compliance requirements are not a big deal.
That said, if you are selling your airplane, do not change the oil and filter. However good your intentions may be, it generates a red flag discussion between the purchaser and his pre-purchase mechanic.
Y is for experimentalI got it too.
So in other words you cannot fly your plane once the oil times out?It generates a caveat in the report. Facts are facts; the inspector cannot make a judgement regarding this AD when the filter is fresh.
I think most people sell their planes because the aren't flying them enough...So in other words you cannot fly your plane once the oil times out?
If a sale is eminent, why not save the media and post inspection remnants to show a potential new owners mechanic.So in other words you cannot fly your plane once the oil times out?
Makes sense.Chris, it's your choice. I'm just sayin' a seller is not always doing himself a favor by presenting an airplane with a fresh oil and filter.
In a prior thread, a poster was inquiring about Titan engines, which may have Lycoming parts with similar connecting rod numbers to those in the AD. My Titan IO-370 lists the connecting rod number as AEL 11750-S; the Lycoming AD part number is LW 11750. I emailed JB at Titan to get a clarification and the following is his response as of today..."The AEL 11750-S rods are not affected by the AD that affects certain Lycoming connecting rods that are part number LW 11750. The Continental rod bushing number is AEL 13923. Continental AEL 11750-S connecting rods and bushings are manufactured by Continental, not Lycoming, have different part numbers, and therefore not affected."Just got notification from the FAA:
Dynamic Regulatory System
drs.faa.gov
Do you have JB's current email? Tks BarryIn a prior thread, a poster was inquiring about Titan engines, which may have Lycoming parts with similar connecting rod numbers to those in the AD. My Titan IO-370 lists the connecting rod number as AEL 11750-S; the Lycoming AD part number is LW 11750. I emailed JB at Titan to get a clarification and the following is his response as of today..."The AEL 11750-S rods are not affected by the AD that affects certain Lycoming connecting rods that are part number LW 11750. The Continental rod bushing number is AEL 13923. Continental AEL 11750-S connecting rods and bushings are manufactured by Continental, not Lycoming, have different part numbers, and therefore not affected."
I assume that this clarifies the AD as it relates to Titan engines. Steve
I got an email from JB "No Lycoming connecting rods have ever been used in Titan engines." ; so this AD does not apply to Titan Engines. Cheers BarryDo you have JB's current email? Tks Barry
[email protected]Do you have JB's current email? Tks Barry
Well that is a relief! I am flying behind a Titan IO360 with close to 1200 relatively trouble-free hours. That said, I cut the filter and check the strainer at every oil filter change.I got an email from JB "No Lycoming connecting rods have ever been used in Titan engines." ; so this AD does not apply to Titan Engines. Cheers Barry
