OK, I'm getting into the fuel and brake sections of my RV-10 build and it's not a topic I'm particularly familiar with. I have the Beringer wheels/brakes from Van's which come with hoses from Flightline Systems, and I also purchased the Flightline fuel hose kit with wingroot filters. I have read through Sections 5, 36, and 37, as well as the Flightlines and Beringer instructions, and checked the wiki. But I still feel a bit lost on how to properly make the connections. And this is an area I want to make sure I get correct.
First, I think that most of the connections are using flared tips -- for example, the connections on the electric fuel pump. I also thought that I should not use any sealing method on those, but section 5 does say to use Loctite 565 on tapered fittings. I would love some clarity on that. I also have Loctite 648 which I used on the Andair fuel selector valve screws (the screws, right, not the fuel line connections?). Finally, I have Loctite 567 that the Flightlines instructions says to use on the fitting to the brake fluid reservoir.
The Beringer instructions mention Loctite 243 and 271 for use on the wheels (I'm not there yet but wanted to mention it).
Can anybody give me some broad guidance on when and where to use the various Loctites? The only thing I know for sure is to make sure it stays on the threads and does not get into the lines.
- Loctite 243: for the wheels -- anything else?
- Loctite 271: for the wheels -- anything else?
- Loctite 565: do I need it?
- Loctite 648: do I use for anything other than the screws on the Andair valve?
- Loctite 567: do I use for anything other than the brake reservoir?
