Hi, I'm replumbing my wing-root fuel filters to accommodate a larger filter with more surface area, as discussed in a previous thread.
I am having trouble because I need to make a 90-degree bend in the line about an inch and a half from the flare.
If I flare the line first, then I can't bend it it the right place without the bending tool crushing the flare.
If I bend the line first, then I can't insert it far enough into the flaring tool to flare it.
I know it's possible - some of the lines that I removed had flares very close to bends - so I'm wondering if there is a technique or a tool that can help me do the same.
For reference, I'm putting a couple of pictures of the tube I need to flare, the type of flaring tool, and the type of bending tool I have.
Thanks in advance for your advice!
Matt
Matt
