nickw9815
I was not a fan of any of the pole mounts available online. A lot of the big brands use a poor design that does not contour to any curvature on the wing with out putting the bolts or rod in bending, and they have a larger form factor. My goal was a low profile mount that I could leave on when not using the pole mount, and have it be able to fit the contour of a wing. Additionally with the spacing of the wing tip bolts, I found making a slightly larger allowed me to utilize 4 bolts per mount.
As for the pole mount, most folks run a standard 3/4" tube that will resonate at specific RPMs. The primary vibration comes from propeller imbalance (at a frequency of 1x the RPM) and the engine firing (at 2x the rpm frequency). If you're flying at high angles of attack or yaw you might notice an increase to the 2x rpm frequency from asymmetric airflow over the propeller. In a perfect world, the camera pole mount would be stiff enough that it would have a resonance frequency higher than all of the engine and prop vibe, but this can only be achieved with a very stubby pole or using high modulus carbon fiber (way to pricey). I ran some calcs to see what the resonance frequency would be of various different pole sizes, and none of the metal ones would avoid hitting the resonance frequency. So I opted for a 3/4" pole with a wood core bonded on the inside to reduce amplitude of vibrations. Results work well, it does resonant at ~1100 and ~2200 rpm but the amplitude is much less than when I had just a hollow rod.
