Jconard said:Ryan:
Please post details about the RV 7 with a sube-a-loop that was faster than the angle valve. Frankly it would be the first.
Second, Cobra, regardless of the cowl opening sizes, there is much drag within the cowl as a result of the coolers. Remember that heat transfer is never fully efficient. If you pick 95% for the sake of argument, air cooled equals 400 degree metal to 60 degree air, one transfer at high delta T.
Water cooled equals metal to water at delta T of 200 degrees or less (unless the metal is actually running hotter in water cooled), followed by radiators at 250 degrees to 60 degree air. Much lower delta T.
So you see that in the water cooled example, we have much lower delta T and the efficiency loss of two transfers, which will require much more airflow at the exchanger to remove a similar amount of heat energy at the cylinder, than does air cooling.
More drag is innevitable.
dserratt said:Look at the crotch rocket market, a 20,000 mile bike is worn out and this is cutting edge formula one technology.
dserratt said:Had to put my 2 cents in to.....
.....EFI is a nice thought except it adds many points of failure.
frankh said:and that is precisely the argument to use modern day electronics in airplanes.
i.e sure your relying on electrical gadgets but if these gadgets are as reliable as the mechanical components they serve then why not?
What new material or manufacture process are we talking about? Not that you think this, but I think people see Lycs as being made by a black smith, pounded out like a horse shoe with a hammer and red hot coals.Fitz said:Technology needs to serve a purpose. In a GA aircraft that needs to either mean more efficiency or more reliability.
Where Lycoming could really benefit is improvement in manufacturing processes and some materials changes at the top of the engine. Add better injectors and do a better job of balancing AFR at the factor (so factory installs can run WOP/LOP for cruise) and they can squeeze some more life out of existing designs still. Put in higher compression cyls and use the improved injection systems to take advantage of ethenol's improved dillution properties and the same 'old' engines of the 50's may well be the new 'green' GA engines of the near future...-jjf
Walter Atkinson said:We use these old technology TCM and Lycoming engines really for only ONE reason.
Nothing else has ever been invented that is as efficient as a Lycoming or TCM piston enigne. Nothing in the automotive world in 2006 (gasoline) has a BSFC(min) in the .385 range like our "old technology" engines. Nothing.
When something better comes along, I'll be in line to buy one.
Walter
Jconard said:My RV/Subaru H6 ECU has many redundant features to keep it running. If there is fuel, air, and electric, it runs.
Are you sure? There is at least one crash which resulted from loosing a minor sensor...leading to "limp" mode, which was not enough to continue flying.
Jconard said:Again, technology is only technology if it serves a need...extra complexity without improved performance seems like change for its own sake.
Jconard said:I wonder about the 2:1 PSRU, my understanding was that the ratio is generally kept at an odd number to prevent repetitive stress. What I mean is that the same teeth will contact each other repeatedly in an even ratio...I guess the reding I have done on PSRU's suggested that such a ratio was bad for that reason...
Comment?
P.S. I will grant the limited value of subjective smoothness, and the convenience of not having to learn how to use a red knob.
Jconard said:Why?
I think such an engine would be cool to look at, but there are many bits of complexity that are unnecesary....
1. You choose 4L in order to spin it faster...why?
2. Individual coilpacks have not proven terribly reliable in the field, often failing without advance notice...ask the 500,000 VW 1.8T, 2.8 24V, W8, owners who had coil pack failures, in a relatively cool underhood car, with packs built by Bosch...not just incidence of failure is important, but fair warning is nice...mags fail, but they give you plenty of notice.
3. Why direct injection? requires high pressure pumps, and is great in the VW/Audis that have it, but at a given, narrow rpm range seems to give little improvement for alot of complexity.
4. If the theory is that smaller package is less weight, hence spin it faster to save weight overall, this just does not seem to make sense, in that it has not been born out by some pretty sophisticated car engines.
5. You do not say it, but I assume water cooled. I await the results of your scoop installation...I will admit to have been following your website. If it works, it may make the drag issue less of a burden, and WC certainly requires less pilot skill to operate, but adds weight, and complexity, and seems to require coolant lines in the cockpit.
You should check out what is required to install a truly redundant FADEC system...I have seem the wiring diagram and install of one....holy smoke are there alot of extra wires.
The highest evolution of the modern, spin it fast approach seems to be trying to replace the 5L Lyc, with the 2.5L Sube, modern everything....in fact it seems that those installs would get alot better if they reduced technology, replacing the sube ECU with a more simple Haltech, or SDS system...map out all the points on a dyno and do some tuning in the air with perhaps a trim control. Find some reliable way to have a mechanical fuel pump, and PSRU/CS prop, and you would be in business.
Sort of like the old injection on the VW buses...bone simple, and robust, with no single sensor failures that can crash it. You may loose the small advantage of colsed loop runing, but the high CR engine has greater thermal efficiency, and it would be simple.
Or even build a balance manifold and go to TBI..two redundant injectors in one spot...clean sheet the thing from block up.
rv6ejguy said:Smaller engine spinning faster weighs less. Revs don't weigh anything. Integrated redrive might weigh 20 lbs. if done right. You don't believe this, look at an Indy Car or F1 engine. About 3hp/ lb. Obviously we won't be spinning 19,000 rpm but the basic idea is the same.
L.Adamson said:I live under an airport pattern, and those high rev "sewing machine" engines sound like "****"! Get too many, and I think I'll have to start complaining about noise pollution!![]()
L.Adamson --- Lycoming 0360 Hartzell C/S
edit: the **** word was c-r-a-p, but since it was surprisingly blanked out, other substitutions will fit just as well!![]()
Funny how when I'm making the noise it doesn't bother me at all!rv6ejguy said:I guess the sound is in the ear of the beholder. Even die hard Lyco guys comment on how nice my turbo Subie sounds. Some people like the sound of a Harley... go figure.![]()
You mean a transmission? I have thought of that, but what does a transmission weigh? May be you mean something else? However that is an interesting idea, and one that even Pratt & Whitney has thought of. The FAN, the big one on the front, has limited efficiency at max RPM, because of it large diameter. It is tied to smaller turbine wheels in the back of the engine that can and do run much faster. You hear it when a hi-bypass jet takes off. The sound you hear is the FAN tips going supersonic. Fancy cowls and sound absorption helps but the sound is distinctive and totally different than an old jet, with it's rocket sound. You actually hear new jets coming more than going.dserratt said:If someone could make a constantly variable ratio redrive like on the new cars conversions could simply run at wide open throttle all the time and use one lever to control prop rpm. just think someone could take a honda s2000 engine naturally aspirated run it at 9000rpm's all the time and have 200HP on demand like a dual shaft turbine.
gmcjetpilot said:What new material or manufacture process are we talking about? Not that you think this, but I think people see Lycs as being made by a black smith, pounded out like a horse shoe with a hammer and red hot coals.
rv6ejguy said:The old Lycos and Contis are pretty good for what they are but the door is slowly but surely closing on them in the experimental world. The tremendous upsurge of the numbers installing automotive based alternatives compared to 10 years ago makes that clear.
Fitz said:We still see premature failures for things like valve guides off center, heads out of round, that sort of thing. That is manufacturing 101 these days. It is probably economics of scale, you can only justify so much modernization for a niche market plant.
There has been a lot of progress in alloys for parts at the top (valves in particular come to mind). Again, this is economics of scale. If you don't have the volume you may not be able to justify the equipment, tooling, and training.
Yea who knows, it is good to dream. Hey what would piston aircraft engines be like if jets happened 10 or 15 years later and technology and capital was invested into better light aircraft engines? May be out engines just dove tail into fundamental laws of the universe. I have some back ground in engineering and design. I see all designs as a series of compromises.Fitz said:I'd have to concur, it is getting surprisingly close. But folks who think we are missing out on massive improvements are (I think) dreaming. -jjf
We might have seen something like the Napier Nomad. It only ran as a prototype, but it burned Diesel fuel, weighed 0.88 lb/hp, and had a specific fuel consumption of 0.345 lb/hp/hr (all data from Wikipedia, so it could be good gen, or complete fiction - pick whichever suits your biases).gmcjetpilot said:Yea who knows, it is good to dream. Hey what would piston aircraft engines be like if jets happened 10 or 15 years later and technology and capital was invested into better light aircraft engines?
Very interesting. I know, those diesel two-stroke, supercharged are very efficient, especially one tied to a turbine! They mention how complex it is. I suspect it may be better suited for a 3,000 hp engine than 160 hp, weight wise. The one they list is 3,580 lbs! The liquid cooling I guess is mandatory, which from my previous rants I'm against, for installation, weight and drag reasons. However just looking at it from a technical aspect, I admire it very much.Kevin Horton said:We might have seen something like the Napier Nomad. It only ran as a prototype, but it burned Diesel fuel, weighed 0.88 lb/hp, and had a specific fuel consumption of 0.345 lb/hp/hr (all data from Wikipedia, so it could be good gen, or complete fiction - pick whichever suits your biases).
Now we're in areas that I don't know. I know this is possible with aftermarket systems.rv6ejguy said:If you can produce documented evidence that high rpm engines wear out sooner, please present it. I think you will find that this is simplistic reasoning without all facts considered. This goes hand in hand with the outdated notion that modern auto engines can't run at high rpm for sustained periods- utter nonsense. I've asked these people to back up their assertions countless times. None have to date.
Simplistic reasoning is all that's needed here. I'm not saying engines can't run a high rpms for a sustained amount of time, all I'm saying is that an engine running fast will wear out faster than an engine running slow (lugging aside wich I would believe to be an non issue in this application anyways).
Things like piston speed, bearing area, bearing journal surface speed, crank support and stiffness, block stiffness, temperature control, Valvetrain mass, cam ramp rates, fit tolerances, materials, hardness and lubrication have the greatest effects on wear rates. High speed liquid cooled engines are very intelligently designed and validated. To suggest otherwise implies that all the engineers that design these engines are fools. Unlikely.
The engineers that design them are not fools, and I never implied such. Engines are engineered for very specific applications. A 180hp, 12,000rpm engine does very well in a 380 lbs sport bike, but will do nothing in a 3,000 lbs car. At the same time, a 500hp V8 is not the optimal engine for a motorcycle (though I admit it can be fun at times)
I know lots of Japanese sport bike engines which have many 10s of thousands of miles on them and have never been opened up. Harley's have historically not had stellar reliability and is a silly design by any modern standard of engineering. It works, has tradition and that noise that some people like but it is crude. The massive engine mounts are a vain attempt to make the bike rideable for a couple of hours.
10's of thousands of miles is nothing for a modern engine, and to brag that an engine has such is useless. Keep in mind that a bike might average 40mph over it's lifetime. At 50,000 miles, that's only 1250 hours. And please don't forget the countless times the valves have been adjusted in that time. And to correct you, Harleys have historically had stellar reliability outside of the AMF days of the lates 60's to early 80's. It is not uncommon for an HD v-twin to go over 100,000 miles and not be opened up, even for valve adjustments. Also, the 45 degree, common crankpin V-twin offers many advantages over other twin designs, despite it's oddfire design. And BTW, you obviously haven't ridden a modern V-Twin, as I've done numerous 8+ hours on mine and engine vibration was not a factor to my discomfort.
People out of the know put forth uninformed ideas about this topic regularly on here and other forums. One derided a popular 5 main bearing, 4 cylinder opposed, auto crank, forged, heat treated with rolled fillets and a demonstrated real world capability to handle nearly 1000hp to a 3 main bearing Lycoming crank which has shown to be prone to numerous failures at 1/5th of this hp level. Bigger is not always better. Small parts have lower mass and lower inertial. More main bearings means less deflection, less vibration, tighter possible clearances. More crank pin overlap makes for a stiffer, stronger, lighter crankshaft and this is proven in the ability to reliably deliver extreme power levels.
No arguments here. Small and light is better in my book to a certain degree.
EFI and rad hoses failing, hmm. those big auto companies must be dummies. I've owned 5 early-mid '80s Toyotas all with over 250,000 km (one with 450,000km) all but one had the original rad, hoses, injectors, pumps, ECU etc. There is over 1 million km. Pretty darn reliable.
Again, the engines are built for specific tasks. And I think you can agree with me that a popped radiator at 45mph on the ground is a lot different that it is at 15,000 ft going 180mph. Also, it sounds like you are claiming to have owned all 5 Toyotas from new - how else would you know that all of those parts are original? That aside, radiator hoses and radiators and all those other things fail all the time, regarldess of car. If you truely had all those cars for that long with all those original parts, then you've been blessed with a collection of freak vehicles.
No one in their right mind today would design a clean sheet engine with uneven firing intervals nor with 2 throws between main bearings (shared throw V8s an exception perhaps) as these designs are inferior in almost every way from a longevity, strength and vibration point of view.
I can't disagree with this statement, though it is still being done. I believe a number of inline 6 engines out there run more than 1 throw between mains, and I know that unshared V8's do as well. And that oddfire V10 that dodge builds seems to do pretty well...
The growing number of people fitting auto engines to experimental aircraft, not to mention Thielert auto based diesels for certified aircraft show that many value the smoothness, low maintenance and refinement of more modern designs.
The Ecotec looks like a great design and several people are planning to fit these to aircraft. With some producing over 1200hp with stock block and crank, these have the basic makings of a reliable 200-250hp powerplant for aircraft.
I love my Ectoec, and can't think of a better small car engine, but would have to see it proven in a aircraft application.
Not all programmable EFI systems need laptops. With SDS, I can adjust any parameter in less time than it takes to unscrew a float or jets to make adjustments to a carb without getting fuel on my hands. We can easily do 25-35 dyno pulls per hour with changes between each run with EFI. Can't do that with any carb, even Webers with external jet access.
xl1200r said:Of course now you just gave me a huge bump in my pants about an HD powered airplane. I'll either have to seriously hop-up a big-inch Twin Cam or buy a lighter kit![]()
pierre smith said:Two things come to mind here. XL, you might just want to read more posts before you start bashing high revving auto engines since this forum has an incredible number of very talented, intelligent engine men and Mechanical Engineers and this subject has been beaten to death....search the archives.
Secondly, if you ever install that shake-'n-bake WW1 Harley engine in any airplane, double the size of the called-for rivets and definitely add a BRS parachute!I have many, many miles on Harleys and Gold wings.....no comparison and still you see guys shelling out over $20,000 for a shaker Harley? No wonder they don't have an airplane!
'Nuff......
xl1200r said:And isn't vibration one of the many concerns with the Lycs anyways? Are people using rivets that are half the size of spec when using a Rotary or Subaru?
