I have been chasing these rpm gremlins ever since putting in my G3X. Overhauled my prop, got a new prop governor, set low pitch stops per the manual, and still having this variable takeoff rpm issue. It seems when we adjust something (low pitch stop, governor screw), we get to 2690 on the first takeoff, but takeoff rpm progressively decreases on subsequent takeoffs. I flew two days ago and was spinning 2680-2690, I thought this was all behind me. Went up today, first takeoff 2640 (after a long run up - busy KSEE), a little frustrated but went ahead w my flight. Landed, decided I could go out a bit on my low pitch stop to see if it helps, went out 1/3, took off no surging, got 2620-2630.
I’m working w BruceH and even went to a different AP on the field to pick his brain and he couldn’t think of what was causing it. He said next thing to check is the ignition system and plugs, then the fuel system, then ?? Has anyone had an issue like this before? Kind of crushing my flying experience and wallet at this point.
It’s a 7A with a O360-a1a with a hartzell constant speed metal prop (74”) and a McCauley prop gov (MT before swapping).
Mechanic said I’m safe to fly but I’ve gotta chase it so I guess I’m chasing it.
