Lightspeed Plasma 3 Ignition Coil replacement
Michael Wellenzohn
Hello,
I have a defective Light speed Plasma 3 ignition coil after 9 years in my RV-10. I learned that this ignition coil model is not available anymore form LSE. The Model is PLV Art. Nr. 356 1 00.
The coil is still available from PLV (German Company) but it has a brass contact pin inside of the insolation (see middle pictures) which LSE managed to remove.
My question is, has anyone experience how to remove the existing brass pins in the PVL to allow to insert the LME pins?
Kind Regards
Michael
Failed spade connection
Is there anything better from these guys?
On my RV9A that I just bought it has these spade connections on the coil pack that are loose to the point that they would have failed shortly if I had not discovered it.
A coil pack with a better locking system on the electrical connections then just a simple spade connections in a high vibration environment.
Even the automotive industry hasn't used stuff like this since the 60's
Tim
Tim
A spade connection properly installed, has better conductivity than an eye and screw...... Install it properly and you will have no problem with them.
Safety the connectors up to the coil with either waxed cord or zip ties. Confirm that they grip properly when you shove them on (loose / wiggly not OK).
Never saw wasted spark coils in the '60's that I can recall....
Does anyone have any removed, serviceable coils that they would sell? I had one fail.
As the new ones are larger and won't fit in the current mount area, I'd like to have a few spares on hand.
P/n is:
P/n is:
I have 4 good ones. I replaced all mine with the new style when I made new plug wires. How a hundred bucks plus shipping?
Let me know.
I’m curious what the new larger coils for the LSE 3 do (or are supposed to do)? My understanding is that aircraft engines with their big bore, low RPM, and dual plugs.don’t need the latest and greatest high energy/duration, spark?
I had a conversation with Klaus a while back and IIRC he seemed to think there was a performance or efficiency increase.
P/n is:
Check you DMs
Widget
One thing to add here (although if you're in the "defective coil" chat already you may already know this...
Checking resistance between the two output towers should yield ~8,400ohm. When my failed it was open circuit. Eventually I found that the symptoms were big time EMI (causing nearby FF and RPM sensors to read abnormally and intermittently), even though mag checks on either ignition did not show any impact on the affected cylinders (eg EGT changes).
