enigmakv
I posted a photo of this on another thread about multiple issues a while back and wanted to start a new thread for this specific issue.
Chapter 18 identifies the AN913-3D plug install. Chapter 41 page 41-03 begins with a caution to make sure the plug is installed since it will not be possible to install it once the wing is installed. Other threads on this forum have included comments where different builders had forgotten to permanently install the plug for one reason or another. I suspect that the builder of my airplane may have forgotton as well to install the plug before attaching the wing and had to do so in the confined wing root area after wing install.
The plug has a square head and I was able to get it out with an open wrench but it was a tight fit. I have found similar plugs with an "innie" hex head that could be done with an allen wrench and will go with that kind of plug moving forward. While I was able to remove the plug, the hole looks like maybe leak repair was attempted a couple of times based on all the gunk in the hole.
I am seeking suggestions and advice regarding plugging this port with the wing attached...
1) Any suggestions for cleaning the hole? I am planning to use a 1/2" wire brush (the port is 3/8") but its gonna be difficult to get a lot of rotation.
2) I am concerned that there might be thread damage. Thoughts/suggestions appreciated.
3) How would you all go about reinstalling a new plug (which sealant, etc.).
The tank on the other wing is being removed to isolate and repair a small leak. That tank had been pulled before so the paint is already cut. I have noticed on that tank that the AN913-3D plug ALSO has a small blue stain around it. Since that tank will be off the plane we will be able to replace the square head with the "innie" head and properly seal it. We'll even be able to chase the threads if necessary so when I put that tank back on there will be no question as to its integrity.
