I'm in the early stages of the project described here. The landing gear are temporarily secured with hardware store bolts and awaiting permanent installation with AN hardware. This plane formerly had a Subaru engine which has been replaced with an O-360 and, of course, a new engine mount, into which the landing gear inserts. The original builder of the airplane strongly suggested that I check the alignment of the landing gear. Misalignment would indicate that the clocking of the gear as inserted into the engine mount is incorrect. Has anyone else ever encountered such an issue before? If so, how did you fix it?
