Jim I am using a MTV-12B/C183-59 propeller and a AIO-390 in my 8 the hub is only 1.250 and VAN'S states you should use a 2.250 spacer I am worried that the air filter won't work with the cowling moved aft an inch would like your thoughts
Thanks Richard
Hi Richard,
I think what you have said is your MT propeller has a 1.25" spacing from the mounting surface of the propeller hub to the back edge of the spinner.
VAN's states a 2.25" spacing from the hub mounting surface to the back of al propeller hub where their rear bulkhead is mounted. The spinner bulkhead has a rear facing flange of about 7/8" thickness. For a 1/8" clearance between the back of the spinner and the front of the cowl, the front face of the cowl is about 1.50" forward of the hub mounting surface.
Normally, the MT Propeller for an RV has a 1.50" to 1.75" spacing from the hub mounting surface to the back of the spinner. This is customer specified when purchased from MT Propeller distributors. I don't know what VAN's does.
It would appear that you just need to mount your cowl to be about .25" behind the spinner bulkhead. Apparently about .5", or less, back from VAN's "normal" position.
I believe VAN's recommends using the propeller to mount the cowl. This is an excellent way to damage the painted propeller and spinner parts.
Create a replacement for the propeller assembly to use to mount the cowl.
BTW, the MT Propeller number you gave is not complete. It could be MTV-12-B/183-59, or MTV-12-B-C/C183-59.
Hopefully, it actually has the 183-59b blades. The -59b blade design is important for performance and the lack of RPM restrictions.
For the Lyc. 360 engine without crankshaft dampeners, the 183-59 blades, there is an RPM restriction between 2050 to 2300 RPM.
There is no RPM restriction on Lyc. 360 engines withcrankshaft dampeners.
For the Lyc. 360 engine without crankshaft dampeners, the 183-59b blades do NOT have an RPM restriction.
You show a AIO-390-???? engine. The fourth place of the model number identifies the crankshaft dampening. A three digit model number does not have crankshaft dampening.
I didn't find any information related to the 390 engine, but would expect it to be no better than the Lyc. 360 engine for impluse loading and harmonic loads introduced to the propeller. One of the fun parts of being experimental.
Regards,
Jim Ayers
