Hi guys,
I've already finished building the IS fuel tank and leak-tested it, and only noticed the inspection port kit afterwards. Installing it will require removing the plate, drilling the hole, resealing it, and performing a leak test again.
I'm not sure how hard it is to inspect the strainer (per 100hr) without installing the kit. If not too bad, I'll probably avoid the hassle and skip it. Do you regret not installing it when you had the chance?
Thanks!
Thanks!
