SwissVolts
Member
Hi,
I have a Lycoming IO-360-A1A (200HP angular valve) that will power my future RV8, and I want to lighten it to improve aerobatics.
Maybe you can confirm if I'm on the right path or help with a better idea to achieve my goals![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1. Cylinders overhaul. I have found some sites in Europe but I don't have any reference... does anyone know Aeroengine? Loma Air? Scan Aviation? any other ?
If I can't find good references, I think I will send the cylinders to Penn Yan Aero, I have read that they are very good!
2. Electronic injection and System32 EFII ignition.
Without magnetos and mechanical fuel pump. Less weight and horsepower increase![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
3. 2x B&C SD8 alternators.
One in place of the mechanical fuel pump and one in place of the dry air pump.
4. Remove the heavy original alternator and change the flywheel for the one offered by Flyefii, light and without a pulley.
5. 2x lightweight lithium batteries.
6. Change the starter motor, I have read that one of the best and lightest is B&C BCS206.
I just built a wooden engine stand, because the typical metal stands are not available in Europe. It seems to be quite robust. Now the work begins!
Best regards
Best regards
