"The rope pull handles are test aircraft feature only, to enable emergency door jettison if needed."
"The fuel tank in the cabin is only for the test airplane. Certain prototype aircraft design considerations are there to enable us to make engineering changes and adjustments (keep in mind, this is an engineering test prototype airplane), easily change configurations in weight/balance, loading, etc."
(regarding ordering)
"No, not yet. This is the engineering prototype, from which we develop the kit airplane. We will take orders once we know when kits can be delivered. That takes some time."
".....There are some features you just can't see (we can talk about those at OSH), and a couple things you mentioned were not quite correct...
Early flight - not the first flight.
Very close on your the take-off roll estimation. Yes - Flaps were up.
Prop correction: Hartzell prop. Big one. Constant Speed.
Fairings come later. This is a test prototype.
Push rod controls. Standard Van's style design.
Trapeze handles are in fact for emergency door jettison. Good catch!
The pilot definitely works for Van's. Great guy, and accomplished test pilot.
Softie is actually a parachute brand.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Correct on the in-airframe latching mechanism.
Again, keep in mind that everything is an engineering prototype design at this point.
The fuel tank in the right seat area is for the test article airplane. Flexibility in test loading, engineering changes, etc."
