Couple of additional data points needed. Ambient air temp and Oil temperature? What oil and viscosity are you running? Should be XPS 5W-50 or AeroShell Sport Plus 4 10W-40 per SI-912 i-001R13 / SI-912-016R18. If the above are all normal, owner's manual suggests check ECU data for info / maintenance check if high oil pressure limit is exceeded. Make sure you burp well before checking oil level as well, and oil vent line is open so overfill can blow out.Curious as to what oil pressure you see at cruise power settings on an iS. I have 24 hours on mine and I am seeing 65-67 which is the top of the green.
