I got in my new to me 12 today and I can not get the canopy to latch. It appears to me there are several problems.
1. The handle I pull and rotate is hitting the blade shape piece it’s suppose to lock behind. See photos. I can’t tell if that blade shape piece is suppose to be inside or outside of the handle. It’s smack it pretty much head on.
2 that blade shaped piece I I referred to above has some hard plastic material that I’m sure the handle is supposed to slide on. That hard plastic material is missing on half of the blade piece.
3. I don’t believe the canopy is coming down far enough because I can see a fairly large gap between the canopy and the fuselage, maybe a quarter of an inch. Perhaps this is the reason I was getting such a blast of cold air on my first flight a couple of days ago. I don’t see anything that’s blocking the canopy from closing more but something isn’t right. I just can’t figure out what it is that’s keeping the canopy from closing and the latch from latching. Any help would be appreciated because I obviously can’t fly until I can get the canopy to lock in place.
When I did my transition training at a Flight school that had RV 12s in their fleet. The latch on the canopy had a switch that would turn on a light on the panel if the canopy was not locked completely. My RV does not have any wires to the latch so there’s no electrical connection to the switch for a warning light. Is that strictly a factory feature and not on the experimental models?
