My 12 is hangared on the south end at KAWO, I'll take a look at my pivot bolts in the next week or so and add to the observations here.Thanks for the data point, Jon. I'll get a small mirror in there soon to see how many threads I've got.
Interesting to see you're based at KAWO--so am I! I'm up in the north hangars.
The physics teacher in me thanks you for posting this, Dan.Use of a swivel at such a low angle would have no effect on applied torque.
Likewise, the extension does not change applied torque.
Question: Is a nutplate equivalent to a standard AN4 nut (50-70 in-lb) or a self locking nut (85 in-lb) ?? per the vans manual torque call out.Thank you for weighing in, Scott. Any ideas what might have caused this? Insufficient torque on the bolts? Nutplates with weak locking threads? Tight roller bearings that impart a light torque on the bolt?
Regarding torque, I used 70 in-lb when installing these bolts--which was intentionally on the lower end of the recommended torque range. My rationale for that was to reduce the chances of binding in a flight control. The recommended torque for AN4 bolts is 50-70 in-lb plus friction torque, so I decided to use 55 in-lb of torque plus 14 in-lb of measured friction, for a total of 69. Which I rounded up to 70. Would you suggest using a higher torque?
The KAI does not indicate any specific value for the the stab attach bolts. This leaves builders and maintainers with using the standard values in Van's Ch. 5 or AC 43.13. Neither of those resources describes any meaningful difference between the various types of self-locking nuts with respect to torque values.Question: Is a nutplate equivalent to a standard AN4 nut (50-70 in-lb) or a self locking nut (85 in-lb) ?? per the vans manual torque call out.
then when adding the friction drag torque you are in the neighborhood of 62-75 in-lb for standard or 100in-lb for self locking.
Which is correct in this application? I don't have a 12 manual/plans, is the torque value for this bolt called out in the plans specifically?
Also, the way I understand attaching flight controls is that if the spacers between clamping a bearing are correct, we should never have to back off of the correct torque. If binding is happening, more work needs to be done to get the spacers/shim/washers lengths correct between the bearing. I read an old thread a while back that talks about the proper elevator attach method after a VAF inspection guy found an RV8 elevator bearing loose because the owner felt binding, so he loosened the nut. That's a no-no
hmmm ok. I was just curious if there is a specified designation for nutplates regarding torque. I guess the way to be safe is torque to 70inlb and make sure there are three threads coming out the nutplate, no binding with free movement, and inspect as often as possible. re-check torque on annual inspection. ??The KAI does not indicate any specific value for the the stab attach bolts. This leaves builders and maintainers with using the standard values in Van's Ch. 5 or AC 43.13. Neither of those resources describes any meaningful difference between the various types of self-locking nuts with respect to torque values.
I agree that the torque vale should be mostly immaterial….but I also have to say…there appears to be plenty of room to address the issue with a castellated nut and cotter pin. Access isn’t that severe and you only do it once, most likely.I may be wrong but for a bolt that is working in shear rather than tension, the torque is immaterial. The purpose of torque is to place the correct working tension on the bolt. I suggest that correct installation for the case in question would be to "snug" the head of the bolt up to the holding bracket and done. The bolt needs to be of sufficient length to be adequately through the nut-plate, as with a nyloc nut. Same principle, different execution.
I no longer own the 12ULS I built so academic interest here. I would probably wire the nuts on next condition inspection if still an owner. I need less things to fret over while flying, not more. I agree with your assessment.I agree that the torque vale should be mostly immaterial….but I also have to say…there appears to be plenty of room to address the issue with a castellated nut and cotter pin. Access isn’t that severe and you only do it once, most likely.
I’ve come up with all kinds of specialty tools for situations like these over many years and the notion that you are able to torque…but not safety…is silly.
Re-stated: Nyloks, or clinch nuts of any kind should be avoided whenever possible.
I think you are missing the point here. As designed, the back side of these 2 bolts are inaccessible once the stabilator skin is on, thus the nut plate. The structure is not like a standard fixed horizontal stabilizer with elevator attached. To account for this a Cam bearing is used and the bolt is not supposed to be an axle but pulled up tight enough to clamp the inner sides of the cam bearing, a perfectly acceptable method of addressing the need. I agree with your assertion that applications where the bolt acts as an axle should be castle nut and pin. In this case it is not possible to use anything but a nutplate by design.I agree that the torque vale should be mostly immaterial….but I also have to say…there appears to be plenty of room to address the issue with a castellated nut and cotter pin. Access isn’t that severe and you only do it once, most likely.
Re-stated: Nyloks, or clinch nuts of any kind should be avoided whenever possible, on flight surfaces
With all due respect…if the tail has the possibility of departing the aircraft in flight, thus killing the occupants…then finding a safe method of safetying that bolt would seem important. Given the notion that two aircraft have demonstrated the same issue in the last few months, would entice me to resolve the problem myself. safety wiring the head of the bolt sounds like a viable option, as does simply creating an access hatch to access the back side of the spar…similar to our aileron bell crank hatch…I think you are missing the point here. As designed, the back side of these 2 bolts are inaccessible once the stabilator skin is on, thus the nut plate. The structure is not like a standard fixed horizontal stabilizer with elevator attached. To account for this a Cam bearing is used and the bolt is not supposed to be an axle but pulled up tight enough to clamp the inner sides of the cam bearing, a perfectly acceptable method of addressing the need. I agree with your assertion that applications where the bolt acts as an axle should be castle nut and pin. In this case it is not possible to use anything but a nutplate by design.
The structure is not like a standard fixed horizontal stabilizer with elevator attached. To account for this a Cam bearing is used and the bolt is not supposed to be an axle but pulled up tight enough to clamp the inner sides of the cam bearing, a perfectly acceptable method of addressing the need....
Yes but it is used in very different applications on those various models.While the stabilator is indeed unique to the 12, interestingly the flanged bearing VA-146 is common to all Vans aircraft.
Bearing, Flanged
store.vansaircraft.com
I'll add another warning about this issue. Yesterday I was doing a pre-flight inspection on my RV-12iS, and I noticed a little play (and a subtle clicking noise) in the left side of the stabilator when I jiggled the tip up and down. So I removed the upper tailcone fairing and checked the AN4 stab pivot bolts. The left side bolt was quite loose, needing about a 1/2 turn to bring it back up to the required torque (70 in-lb, which includes friction torque). The right side was also a little loose, needing about 1/8 turn to bring it back up to torque. I recall carefully torquing those bolts just over a year ago during final assembly, and my airplane has been flying for only 7 months/85 hours (so it has not had a condition inspection yet).
I'm quite surprised these bolts loosened this much in such a short amount of time. Based on the discussions in this thread, I plan to replace the bolts with drilled-head versions soon and safety wire them in place. Lesson learned is to carefully check for this issue in every pre-flight inspection! Make sure to actually jiggle the stab tips to feel for any new play and listen for any clicking noises.
This is an RV12. I’m a builder of mine. If you can get a nut on the back of that bolt carry on. It’s totally inaccessible.I agree that the torque vale should be mostly immaterial….but I also have to say…there appears to be plenty of room to address the issue with a castellated nut and cotter pin. Access isn’t that severe and you only do it once, most likely.
You have to read the whole thread. To answer your question, no access. It is a one side access configuration with a nutplate. When elevator is in place access is poor to nil.Wouldn’t a castellated nut and cotter pin solve the problem?
All certified aircraft require castellated nuts and cotter pins on all primary controls. Regardless of what the kits manufacturer allows…that logic makes the most sense to me.
This is not exclusive to the RV design architecture. If the pilot community decided that this was a concern, we would need to redesign all the Cessna‘s, Piper‘s, Beach, crafts, Moonys, fill in the blank with any other model, that we fly in generally aviation because they all have this type of hardware configuration all over in their control systems.On my RV-7 I can't see nuts and bolts in the control system. For example aileron bell crank in wing, especially right wing where the autopilot servo is, there are many bolts with nylon locking nuts. I don't love it. You can't inspect those control fasteners without taking inspection panel off, not practical for daily preflight. I am thinking of drilled bolts, castellated nuts/cotter pin, at least for the servo linkage. Otherwise you have to rely on regular inspection, no more than 12mo.
I don’t personally have a problem with it, but it does bother me, when a lot of these things come up in the forums, it often drifts toward peoples tone implying that they are being safer than others because they choose do something different just because one instance in an entire fleet of airplanes occurred. And secondary, a tone of why wouldn’t everyone do this?Obviously if safety wire, cotter pins, torque, etc is/are not performed properly safety is compromised. The stabilator hinge bolt has never been a reported problem, except for the OP one. That said, I don’t see why the defense to adding another level of safety. I was just working on my -12 engine mount, a torque value is given and a cotter pin is required. We torque the magnetic plug on the 912, and safety wire it. I am sure there are many other areas that get a torque and safety wire or cotter pin that don’t immediately come to mind. What is the problem with adding the safety wire on the stabilator bolt for another level of protection?
Has not been a problem that you know about. There is no requirement to report it with EAB. In Certified planes if an A&P or AI finds a serious safety of flight issue they have a mandatory obligation to report it. This is how AD (Airworthiness Directives) happen on small planes and Airliners alike. Service Difficulty Reporting System (SDRS) is mandatory for serious defects or conditions affecting airworthiness must be reported, even if the owner/operator is ultimately responsible for ensuring the aircraft is airworthy. Never heard of it so not a problem is not sound logic. I get your point but don't count on it. For us EAB RV builders and owners, we have Van's service letter bulletins. The FAA can not issue AD's on EAB's I recall. On my RV-7 the horizontal stab spar developed cracks on some planes. So this is an area to inspect and explains the repair if crack is found.Obviously if safety wire, cotter pins, torque, etc is/are not performed properly safety is compromised. The stabilator hinge bolt has never been a reported problem, except for the OP one. That said, I don’t see why the defense to adding another level of safety. I was just working on my -12 engine mount, a torque value is given and a cotter pin is required. We torque the magnetic plug on the 912, and safety wire it. I am sure there are many other areas that get a torque and safety wire or cotter pin that don’t immediately come to mind. What is the problem with adding the safety wire on the stabilator bolt for another level of protection?
I don't know if you are referencing me. I did not say your are not as safe without safety wire. I would say that inspecting these bolts during preflight is a great idea. As jetset44 said you can get a peekaboo view of the bolts in question with a light and you can wiggle the Stab. My point better inspection access might be something to consider. Your other post you say safety wire and cotter pin does not work if not installed properly. That is true, but the point in this thread is about the RV-12iS's two Horz Stab bolts. These critical bolts are held in with friction (nut plate). That is it. If torqued properly and during operations there is no anti-torque forces (loosening) the bolt or vibrations it should be fine.I don’t personally have a problem with it, but it does bother me, when a lot of these things come up in the forums, it often drifts toward peoples tone implying that they are being safer than others because they choose do something different just because one instance in an entire fleet of airplanes occurred. And secondary, a tone of why wouldn’t everyone do this?
Probably the only downside to VAF is the social media failure analysis. It typically goes the same way:I don’t personally have a problem with it, but it does bother me, when a lot of these things come up in the forums, it often drifts toward peoples tone implying that they are being safer than others because they choose do something different just because one instance in an entire fleet of airplanes occurred. And secondary, a tone of why wouldn’t everyone do this?
I am the OP. I don't know what thread you are talking about. Seems to be a list of Pet Peeves that are relevant to this thread. This thread has been very productive with great inputs. I don't understand most of your bullet items.Probably the only downside to VAF is the social media failure analysis. It typically goes the same way:
Post with a picture of a problem.
Post saying it should have been found during inspection
Post saying it’s a design flaw
Post saying it is added to preflight checklist
Post with an unworkable solution
Posts with engineering buzzwords.
Dunno. If you look you can find a post or two recommending “running a tap” through nut plate threads to make it easier to get the bolt in.
