william62696
Member
Title is to attract attention but I suspect it is only an indication issue.
Engine @ 1000RPM = ~105 PSI indication.
Engine not running = ~ 42 PSI indication.
The oil pressure transducer (Stewart Warner 411K) was R&R'd with identical results. The wiring has been inspected with no anomalies noted.
I have done some dumpster diving in the airforce forums and my guess is the culprit would be the gauge but would like your input. Another thought - is there a procedure to calibrate/adjust the gauge?
If you also agree that the gauge is most likely the culprit, does anyone have one lying around from an upgrade, as the Mothership no longer supports the gauge?
Thanks in advance!
-Billy D.
Thanks in advance!
-Billy D.
