I riveted on the F684 gusset plate on the lower left longeron/firewall engine bracket. When I set the last (forward) rivet, the shop head was a little thinner than the rest. Upon closer examination, there is a slight gap behind the gusset plate at this rivet. The cause was because I drilled this one rivet out and had to tap the shank with a punch. I must have just slightly bent the plate outward. This is a long rivet, so I’m hesitant to drill it out again for fear that I’ll cause more damage. Looking for some thoughts. Leave it or try to rework it to get the gusset plate tight?
