I added the GA-35 antenna for my GPS-175 just aft of the Dynon GPS and ELT antenna on the aft top fuselage skin. It is probably the best location for following Garmin's mounting instructions. In IFR, you really want to have a reliable view to the GPS constellation. I did have to fabricate a doubler, but that was fairly easy to make and install.
Rough position on the upper aft fuselage behind the ELT an
I am beginning the installation of a GPS 175 in an RV-6. Does anyone have experience with mounting the GA35 on the glareshield ? I have the Dynon GPS 2020 antenna and ELT antenna mounted aft of the canopy, and don’t want to mount it there. I don’t really want to go in front of the windscreen. The glareshield (upper fuselage skin) just inside the windscreen seems like a possible choice. Anyone with experience with it there?
I have installed the GA35 on four aircraft on their glareshields and they have performed well; two were RV's with aluminum glareshields, and the other two had fiberglass. The fiberglass has to have a ground plane under it with a radius of 7.5 inches. The manual says it can be heavy duty foil tape, but I used some thin aluminum sheet, and had the screws from the GA35 bonded to it. One was a VFR install and I could not get the full 7.5 radius for the ground plane, so I made it a bit narrower and wider to fit, and it worked well. I painted them all with flat black non-metallic spray paint; Just make sure you have the correct length of coax going to them and you should be good.
