Velcro Loop Fabric Glareshield Cover
I made a Loop Fabric Glareshield Cover.
If you want to make one, here is the link to buy the fabric.
Loop Fabric
I suggest buying 72" so you get more than enough to span the glareshield.
Process is pretty simple
Buy a pack of single sided laminating sheets at Wally
Snag the kids deck of playing cards. Make sure you buy a new deck! We had index cards.
-Lay a laminating sheet sticky side up on the glareshield leaving an inch of space fore and aft.
-Place playing cards into the windshield/glareshield seam then press them down. Use the short side so they confirm to the curve.
-Repeat till the entire glareshield is covered with a some overlap on the aft edge. Slip the next sheet under the current one and press it down. Keep placing cards.
-Draw a line using a marker along the aft edge from underneath
-Make some alignment lines so the two halves can go back together on the bench
-Remove and you have a template.
-The vent holes were easy. Cut the area an inch bigger then the vent. Place the template on the glareshield. Use a ruler to extend the edge lines onto the template. Remove the template. Tape new cards in place. Extend the lines back over the new cards. Cut out the area. If it's a circle, you're on your own. I got nothing for that one.
-Cut whatever fabric you like.
![20231014_154543.jpg 20231014_154543.jpg](https://vansairforce.net/data/attachments/29/29675-bbc1f2abea3abef37fbf1650b020a5e1.jpg)
