How about AxisPert ? lol"AXPERT" doesn't have the same ring to it.
Just makes you sound like a murderer, Canadian tuxedo aficionado, or someone who frequents hipster bars...
Will any of the hardware be at OSH for us to gawk at?
We will have two fully wired panels showing Axis systems including the Nav/Com version at our booth.I'm willing to bet the entire Garmin tent will be filled with Axis. As well as every reseller.
Absolutely. We will have some great opportunities to get hands on experience with the AXIS equipment at Airventure 2026!Will any of the hardware be at OSH for us to gawk at? I've been planning a panel refresh for some time to replace my 2-screen non-touch G3X and TruTrak GX Pilot autopilot, all of which are showing signs of age. My com/nav suite, consisting of an SL 30, GTN 650, and a PE audio panel, seems to be aging more gracefully. That said I'll probably yank everything and start over, but I want to learn more about the new system and weigh the pros and cons of maybe keeping select components, like the GTN, from my current setup. In any event Looks like I finally got the timing right on something.![]()
There is a clear mention to Axis being compatible with GMU11 but no mention to GMU 22. Is GMU 22 also compatible?We will have two fully wired panels showing Axis systems including the Nav/Com version at our booth.
See post #13 in this thread.Is this available somewhere?
Yep! This is absolutely compatible with the new system.There is a clear mention to Axis being compatible with GMU11 but no mention to GMU 22. Is GMU 22 also compatible?
How About the GMA35C audio panel?Yes, a GMU 22 connected directly to a GSU 25 or GSU 73 is supported in the AXIS system.
I read in the install docs that the GMU 22/44(B) are compatible.There is a clear mention to Axis being compatible with GMU11 but no mention to GMU 22. Is GMU 22 also compatible?
The VP-X Pro is fully supported in AXIS.How About the GMA35C audio panel?
Currently I have the GMA35C integrated to my GTN750Xi.
Would the Axis system be able to command the Audio panel, through the HSDB connection to the GTN750Xi?
How about VPX-PRO? Is there an app / widget for VPX integration?
Thank you so much for your replies!!At this time, GNX 375 ADS-B Data does not enable Runway Occupancy Awareness in AXIS, a GTX 345/45 is required for this function.
Understood. thanks!The VP-X Pro is fully supported in AXIS.
The GMA 35C does not integrate directly with the AXIS displays at this time. AXIS Internal audio panel and GMA 245 variants are the only fully integrated audio panel devices. The internal intercom of GTR 205X(R) radios is also tightly integrated with AXIS.
Thanks for chiming in.. can you clarify this section of the IM:The integrated GAD29 is built into the GDU116C / NC versions, not the base model. If you are retaining the GTN and upgrading the EFIS from a GDU460 to a GDU116BX then you will keep the GAD29 but will still need to connect the GTN and transponder to the Axis display.
GDU 116 COM and NAV/COM display variants include built in ARINC 429 in/out ports. In this case, a
GAD 29 or GSU 73 is not required to interface with external navigators that require ARINC 429
connections with the AXIS displays in the system. However, a G5 in the system is not capable of receiving
ARINC 429 data provided directly to an AXIS display. To share external navigator ARINC 429 data with
both the AXIS display system and a connected G5, a GAD 29 or GSU 73 must be used.
The way I read this, it seems like a compelling way to "IFR-ize" an existing VFR G3X system, without having to do a lot of rewiring or cutting your panel. Currently, a VFR bird with G3X Touch that wanted to update to allow for IFR would at a minimum have to add:
or:
- IFR GPS (GPS 175 or similar) - new panel hole
- ARINC 429 (GAD 29)
- A second NAV/COM radio (GNC 255A or similar) - new panel hole
- Audio panel (GMA 245R or similar) - new panel hole
Unless I am reading something wrong, all of the above can be achieved by simply swapping the single GDU G3X display with the new one. Likely simpler wiring, too. Am I missing something?
- All-in-one IFR navigator (GTN 650Xi or 750Xi) - new panel hole
The only thing I don't like is: "If you have multiple G3X Touch displays they all need to be replaced with AXIS."
That's too badIs this a temporary limitation, or will they never talk to each other?
Any plans to incorporate this down the road? Would be odd if not, I would think….
Understood. thanks!
Apart from the fact that the audio panel function is available for the GMA35C, the system would still be compatible with NAV/COMs right? to tune frequencies from Axis display?
Only thing is that the audio selections would continue to be done on the GTN750Xi screen, right?
g3xpert,
Will the AXIS support the higher resolution terrain databases than what the Touch does?
Are there any changes for the GARMIN PILOT to transfer flight plans to/from AXIS via Blue tooth or WIFI? to/from IPAD and/or ANDROID phone?
How about SmartCharts? is it already there in the Axis system?![]()
It sounds like if you use a G5 backup, you'd have to have a GAD 29.
Or am I reading that wrong?
G3x guy said you don't need the GAD29 with the Xi unit? I'm confused...The integrated GAD29 is built into the GDU116C / NC versions, not the base model. If you are retaining the GTN and upgrading the EFIS from a GDU460 to a GDU116BX then you will keep the GAD29 but will still need to connect the GTN and transponder to the Axis display.
ARINC 429 via GAD 29 or GSU 73, is an optional but recommended backup path to include, if you have a G5 in the system alongside a GTN Xi, GPS 175, GNC 355, or GNX 375.G3x guy said you don't need the GAD29 with the Xi unit? I'm confused...
With the 'standard' dual GDU install and the Xi tied to both screens you really don't need the GAD correct?The purpose of including ARINC 429 from a HSDB connected navigator is to provide a backup path for External navigator navigation data, in the event that the primary display fails. G5 is not on the HSDB network. If the primary display fails, but your GTN Xi and G5 are still operating, you need the ARINC 429 datapaths to display navigation data from the GTN Xi on the G5.
Fits an existing G3X hole, thinking this might be an awesome option for the 8s given the space restrictions!Not sure how this will work in an RV-8. Need to get the tape measure out and see if I can fit it in with the required nav and com stuff.
At first glance I think it will. If the foot print is 11.6”.
First, thank you Garmin for continuing to make forward progress with a great product.
In the future, can Garmin champion its customer base in the experimental/homebuilt market and provide roadmaps for its model development with timelines? Please, please , please.
There is a group of builders (myself included), that are frustrated by the lack of transparency with Garmin's development timelines. I'm literally finishing up the final installation of a G3X system and I would have gladly waited a year or even more if I had know these developments were finally coming fruition. If i knew it was more like 3 years off or more, I would have stuck with going with a soon to be retired system as a guess. At least I would have made an informed decision.
I understand that providing a roadmap may be considered a give up to competitors and may be perceived as cannibalizing current sales/income, but if we are truly customers and partners in each other's success, communication would be a cornerstone. NOT being negative on progress, I'm just clear the lack of transparency may benefit Garmin in many ways, but there is a segment of the experimental market that you are definitively not partnering with as best you could to benefit the customer relationship.
Can I ask how does the G5 as a back up integrate into the Axis system? If the screen on the axis system were to go down what could the G5 handle?ARINC 429 via GAD 29 or GSU 73, is an optional but recommended backup path to include, if you have a G5 in the system alongside a GTN Xi, GPS 175, GNC 355, or GNX 375.
Also, being off line most of the time at work, is there a PDF of the information about the Axis system available at all?
Besides the previously mentioned backup navigation data, the G5 will crossfill ADAHRS data in the case of a primary ADAHRS LRU failure.Can I ask how does the G5 as a back up integrate into the Axis system? If the screen on the axis system were to go down what could the G5 handle?
Hi Justin,Absolutely. We will have some great opportunities to get hands on experience with the AXIS equipment at Airventure 2026!
We would be happy to work through the specifics of your installation with you there. You can always contact us directly at [email protected] as well, where we can help talk through the options for your panel upgrade.
Justin
How much would be a COM, intercom and ARINC 429 be that you don't get with the Bx model. The $18k would cover those also.
