GAP26 AOA Probe
rv8or
I'm fitting A Garmin GAP AOA and have a couple of questions.
1. What type of fitting do you use to change from the aluminium tube to the plastic tube, note this fitting needs to pass through the standard pitot tube mount.
2. The power wires are very short so how have you connected them and if you had to extend them, what method did you use.
Thanks Rob
Cut the tube to give 1.5" clearance from the top skin (at least) and flare, it is a -3 tube.
Use a 90* -3 flare to 1/8" NPT adapter
Use a 1/4" push fit to female 1/8" NPT connector
Power wires - whatever is needed, crimp on additional wire using an in-line crimp, terminate the ground wire to a nearby ground stud.
FYI- if you decide to shorten the aluminum lines where they transition to soft lines, there's a minimum length spec in the garmin installation instructions in order to give some distance between the heated probe and the flex lines. I want to say it's 8" but my memory is a little fuzzy on that so please look it up if you go that route.
For the wires, I prefer the knife splice (handshake) terminals. Easy to disconnect and small. You could also use male/female spade connectors - 3/16” ones if you need smaller.
For the pitot and AOA lines there are several options. An easy one is to use the push on connectors if both aluminum tube and nylon tube is the same (1/4”). These work fine under positive dynamic pressure. Some of them don’t works as well under a negative pressure like you would see in a manifold pressure/vacuum line. You could also use a push on connector that has a male or female threaded end on one side, but that might not fit through the pitot mast. Another possibility is just get a piece of silicon hose with an ID that fits snugly over both tubes - it stretches.
Thanks Rob
This is how I did it. Electrical will be uninsulated butt connectors, then covered with adhesive heat shrink.
A cautionary note - for the RV 14, if the pitot is mounted in the left wing where Vans has you also locate the magnetometer (Garmin), grounding the pitot heat locally to a rib in the wing “may” cause enough magnetometer interference to fail the test (did in my case). I ran a dedicated ground wire back to the fuselage. Twisted pair of pitot heat wires routed away from the magnetometer may also be beneficial.
I must apologise, I realised I haven't replied and offered thanks for the replies, it comes with age.
I will use push fit 3/16 to 1/4 fitting as suggested.
For the electrical connections I will mount a small barrier terminal block that will give easy connections using ring crimps.
Thanks for the replies.
All the best
Rpb
