I'm fitting A Garmin GAP AOA and have a couple of questions.
1. What type of fitting do you use to change from the aluminium tube to the plastic tube, note this fitting needs to pass through the standard pitot tube mount.
2. The power wires are very short so how have you connected them and if you had to extend them, what method did you use.
Thanks Rob
Thanks Rob
