jliltd
True. But if not in config mode you cannot monitor progress of each LRU update so you don't know when to tell VPX to turn on the remaining LRUs in sequence.What I was able to verify as long as you don't install an update in the config mode AND your VPX is in communication with the MFD (vs the PFD) you can turn off each circuit in the VPX to help with the install as needed but with 9.51
