> I'm implementing a new G3X Touch system with a G5 as a backup instrument. I plan to connect the G5 to the CAN Bus. Do I also need to connect the RS-232 interface? If so to what device?
The G5 can get all of the needed information from the CAN bus.
Thanks Kirk. My question on the ELT is with the Serial connection. In their drawing they show a wire going from the ELT RX Pin which I am running to GTN650 RS 232 TX. They also show a ground which is not attached to anything. I was wondering how I handle that ground.I think your question(s) about the ELT are covered in this recent thread: https://vansairforce.net/threads/artex-345-remote-pinouts.232131/. And I think you want to ground the GTP59 OAT probe locally (well, I'm using my chassis for ground so that's what I'm doing).
I asked Garmin about the G5 connectivity -- based on this answer I'm not wiring RS232.
Everything looks good to me.
Yes, I did have a mis type on the labels. I double checked the pin numbers and they wor good. Thanks for catching that.I didn't check your pin numbers, but it looks like you have some ARINC 429 TX versus RX confusion between your GAD 29 and GTN 750.
An RS-232 interface between your GTN 750 and your G5 is indeed optional, but for various reasons I would connect it if given the opportunity, which you certainly have. Do this by connecting the RX pin on the G5 to the same TX pin on the GTN 750 that is being used for the MapMX format.
Redundancy, and there is data available via the MapMX connection which is not available via ARINC 429. It's not a required connection, but if you are doing a new installation, the cost of one extra wire is as close as it gets to free in aviation.What does MaxMX give you on the G5? Right now (flying RV-10) I have a G5 but it is completely detached from the G3X system so I might be missing context for what the G5 would use the MapMX data for.
That's correct, the MapMX RS-232 connection is required for a G3X system, so if your GTN is navigator #1 and you're already connecting something to that RS-232 port, there's no good reason not to connect it to the G5 as well.As I understand the G3X IM, connection to a GTN and GAD29 is optional, not that MapMx is optional when G3X is connected to GTN and GAD29.
Originally I tried using the symbol editor to make the boxes with pins but that was a problem when I needed to change pin and connector positions for certain placements. Right now I’m creating them on the schematic as I need them. I’m open to suggestions of a better way though.Those schematics look nice. It looks like you used kicad. How did you get the garmin “boxes” into it to place on the schematic. They aren’t in the library that comes with kicad as far as I can tell
Pete
Thanks Kirk. That answered my question.The way I interpret their drawing is that you run one 3-conductor, shielded cable from the avionics to the ELT. One wire is RS232 out from the GTN. The other two wires connect to the panel switch. On the avionics end, the shield connects to the RS-232 ground pin on the GTN. On the ELT end, the shield connects to pin #7 (ground) which also should be connected to the chassis ground.
My question about formating more than 1 RS-232 ports to Mapmx wasn't answered directly, but judging from comments made, it looks like the answer is no.
So I will jumper the G5 RX-232 RX to the same GTN R-232 TX pin as the one going to the GDU. Thank you everryone. I believe I've got all my questions answered.
Dan
That was my thinking.Ahh I missed that possibility. If that's true then it is a bit confusing that the MapMX to the GDU is shown as 2-way but to the G5 is shown as one-way. So are you going to set up transmit/receive between the GDU and GTN and then only connect the TX (from GTN) to the G5?
