Hi everyone, thanks for your patience as we’ve worked to investigate the reports mentioned in this thread, and other similar reports.
Among the numerous reports of varying behavior relating to the display of TFR information, some can be attributed to variability among different data streams, and others to a problem the team has identified in our equipment.
There are a few aspects of the FIS-B data stream that can account for discrepancies in the display of TFR data across different devices. For example, ADS-B ground stations only transmit TFR data via FIS-B for local TFR’s – ‘local’ here means a look-ahead range of 100NM (see Advisory Circular 00-63B, Figure A-3). Additionally, only NOTAM-D and NOTAM-FDC products broadcast that were issued or effective within the last 30 days are made available via ADS-B (AIM Table 4-5-3). These are a result of the function of the ADS-B system, rather than an avionics or device specific function. In contrast, an EFB drawing on internet data (or stored internet data) or SiriusXM data would likely provide the data described by either of these cases, potentially leading to conflicting information between different devices.
In addition to these inherent sources of variability, our team has been able to identify a graphical TFR issue in our display products which leads to lost data in certain circumstances. The following products are affected:
- G3X Touch displays running v9.52, receiving FIS-B data from:
- GDL 5X(R) v2.23
- GDL 39(R) v4.91 (only Bluetooth connection affected)
- GNX 375 v3.22
- GTX X45(R)(D) v2.90
- Aera 660 and 760 running v4.21, receiving FIS-B data from:
- GDL 5X(R) v2.23 (only RS-232 connection affected)
These issues will be corrected in forthcoming software updates. We will update the group here when these are available for download.
As always, please feel free to reach out to
[email protected] to get connected with our team.
