scorwin
Active Member
Flew my RV-10 (IO-540 with dual pmags, 80 hours on engine/plane/plugs) from DFW to TUS last week after getting it painted and some work on cooling (cowl flaps, condition inspection). During that flight, the engine sputtered a couple times, almost felt like the nosewheel was shimmying, would only last maybe 1-2 seconds. No change on EFIS. However, one time, there was a 3-5 second sputter, where I lost all CHT/EGT from cylinder 5 and then when then engine was flying like normal, the info returned. I cant remember the CHT but the EGT went from around 700->900->1100->1350 (normal). The first couple hesitations, I had fuel at 10.5 GPH, flying at 10.5k, so I simply bumped it to 11.0 GPH, in case it wanted more fuel. Around 90 minutes outside KTUS (home), CHT started to slowly decrease from 340 down to 315 when I landed. Engine ran fine. If I didnt have the monitor, I would not have noticed. No change in RPM or speed.
Taxi to hangar and call mechanic. Swap out plugs from cylinder 1 and 5, start it up. Kept it at 1400 RPM to get oil temp up (doesnt take long here in the summer), then 1900, then at 2400 RPM (all on ground with cowling off). Mechanic tells me to shut it down. CHT all the same throughout. He noticed the blue stain around the plug, didnt smell or notice anything with the runup.
Plan on his end is to clean up the plug. Run it again with cowling on. Fly it if run up is good again and then recheck the area around cyl 5 to see if there is any leaks.
Reasonable plan? This is a new-to-me mechanic.
