I think I am in the final steps of my first condition inspection. I talked to an IA on the airport yesterday and he said I should clean my fuel injectors nozzles. I am reading a lot more about this, most of the information seems anecdotal, not source material.
One publication in the 2010's said it was important maintenance to. perform annually.
One from the 2020's said per the Gami guy and MB that more problems are caused by opening the fuel system and that those with engine monitors can follow data to learn of problems.
Lycoming Service instruction 1275C seems to say to perform at overhaul and as engine conditions require.
www.lycoming.com
So, for those of you that maintain your own planes, what do you do and why?
Is there source material other than the service instruction that suggests I need to perform this as routine maintenance?
I have an IO-540 with engine monitoring that seems to indicate NO problems.
Service Instruction No. 1275 C
Supersedes Service Instruction No. 1275B September 23, 2008 MODELS AFFECTED Precision Airmotive RS and RSA Fuel Injectors installed on Lycoming aircraft engines. TIME OF COMPLIANCE At overhaul and as engine conditions require.
