I am planning to put a flap switch on the throttle of the "Brand S" that I am building. Why you ask? Because it has electric flaps and there is no provision for a Johnson Bar. The ability to vary the amount of flaps going up or down is available without reaching for a panel mounted switch. I like flying with a Johnson Bar on STOL aircraft because you can easily control the rate of feed the flaps have for cleanup after a soft/short field takeoff, or flaps down to get off the ground quickly, for example. You're going to be changing the throttle settings during these type maneuvers anyway, so why not make it a bit more elegant? I won't get the same feedback as from a Johnson Bar and manual flaps, but I will have the ability to milk in or out flap settings with my left hand staying on the lever style throttle handle.
Has anyone built a hand grip with a MOM switch installed for this purpose? Maybe 3D printed? If so, I sure would appreciate a picture. The switch should be mounted in such a way that it is protected against inadvertent movement. Using your thumb would be the most comfortable for activation and mounting the switch on the inboard side of the throttle grip keeps it out of the way when not needed.
You could also install a panel mounted flap switch in parallel for the right-seater if you have that need.
