I took the diagram as drawn, so I subtracted the W-00026 thickness, and I also subtracted the WD-1013A thickness, so that I could measure inside to inside if that makes sense.
Don't know if that's right at this point, as I just put the left arm in last night, and don't have wings and flaps to test yet. But I will add it seems to be close enough, all the bearing blocks are lined up on non painted surfaces, and it looks like 1 or 2 16th" won't make a large difference.
The red circle is the outside edge of the WD-1013A, so you can see there is room for the bushing block there.
