I have a slight gap (approx. .050") between the edge of the rudder skin and the lip of the joggle in the fiberglass tip. indicated by arrows in the attached photo. The gap does not run the entire length, only in the middle. I'm looking for the best way to fill this gap. Can I simply tape the rudder skin right up to the very edge, then with the tip clecoed in place, fill the slight gap with thickened epoxy? I'm guessing the would require a minimum amount of epoxy. Once cured, I would feather the epoxy to the rest of the tip. Would this not result in a lip that it now buts nicely against the entire length of rudder skin? Comments or suggestions appreciated.
