So during a start with it off the batt would have more power for start but leaving it on would not cause any issues if all is in good shape. True or falseThe Field current/voltage is what energizes the alternator and controls the voltage output based on the voltage regulator. The field must be energized for the alternator to charge your battery and run your avionics. 3 amps is a normal current draw, 7 amps is the common circuit breaker value. Under normal operations, the field switch must be on..
This is the first airplane I have flown since 1951that had this switchSo during a start with it off the batt would have more power for start but leaving it on would not cause any issues if all is in good shape. True or false
Its current is minimal. What kind of alternator? Internal or external regulated?So during a start with it off the batt would have more power for start but leaving it on would not cause any issues if all is in good shape. True or false
Most Piper / Cessna / Beech / Grumman / etc.... in other words most Certified aircraft have a split Master switch standard, the one side energizes the master contactor while the other side is a "field" switch.This is the first airplane I have flown since 1951that had this switch
In all likelihood it is not.This is the first airplane I have flown since 1951that had this switch
The Plane Power (a.k.a Hartzell Engine Technologies) guys said at a forum at Oshkosh a few years ago that they recommended having the alternator off during engine start.So during a start with it off the batt would have more power for start but leaving it on would not cause any issues if all is in good shape. True or false
That places you at least 90.... Fly on....This is the first airplane I have flown since 1951that had this switch
An alternator field switch is not really necessary. I used Bob Knuckoll's electrical system architechture, which just specifies a pullable circuit breaker for the alternator field. The only time you expect to pull the breaker is to corral a runaway alternator. Otherwise you just leave it closed.This is the first airplane I have flown since 1951that had this switch
If you have a nippo or automotive alternator with internal regulation, your car doesn’t have an alternator field switch, so it is always on.
Don’t know. Sounds like a good research project for you.Are you sure the car's onboard electronics aren't sequencing the Alternator field so it only engages once the engine is running? It would be trivial to do, and would be a lot easier than explaining to the average driver what the field switch was on the dash.
have you never flown a Cessna?This is the first airplane I have flown since 1951that had this switch
While this used to be true, it no longer is. In modern vehicles, the alternators voltage regulator and therefore field current, is controlled by the ecu. To reduce starting load, the ecu will not ramp up the alternator output until after the engine starts. In addition, the ecu is constantly adjusting the voltage level, so it acts more like a smart battery charger. They no longer constantly throw 14.4 volts into the system. Most now float around 13.6 after they have determined that the battery is fully recharged.I don’t think you’ll find consensus on turning an internal regulated alternator on before or after start.
If you have a nippo or automotive alternator with internal regulation, your car doesn’t have an alternator field switch, so it is always on. Ever had an alternator failure in a car?
I went through a couple alternators before I started switching it on before start and never had another issue. Was turning it on after start part of the problem, who knows…..
Plane Power has suffered some reputation damage over the past few years so I’m not buying what they are selling. I don’t get what they mean by “why would you put your alternator through that”, through what? What a normal alternator sees every day in a car?
Anyway, to the OP, best to identify what alternator you have and follow the manufacturer’s recommendations, if they have any.
