I'm just getting ready to deal with the cowl fitting. I didn't have the PVC or plastic bits on hand to make the EZ Cowl jig, and I didn't want to spend $400 on the super nice machined ones, so I decided to 3D print it instead. TBD if it works, but for less than $10 in filament, worth a shot. I did the math (hopefully) and made the jig the right depth to account for the 2 1/4" spacer (using a Sensenich GA prop), spinner backplate, 1/4" cowl gap, etc, so it should be the right size to set the cowl nose bowl in the right place. In hindsight, I should have printed some arms off of the sides to allow for clamping to the disc that attaches to the cowl. I'm just going to use a nice flat piece of plywood or MDF for the matching disc that is clecoed to the cowl. I was a little uncertain that just using a piece of scrap 1" dowel for the center locating pin would be stiff enough, but it's a snug fit and perfectly square - plenty strong to hold the cowl in place.
Happy to share the file if anyone wants it (FYI - the bolt holes are sized for 1/2" bolts, but I could make a 7/16" version easy enough if necessary). For thickness changes, you could easily just make up any differences you need by stacking wood on top of the printed part.
