i looks like we may need a fuel pump for my friend's RV6A (O-360 AIA).
Any opinions on models/brands that work better (or worse)?
(Symptoms: As soon as the engine warms up, fuel pressure drops below 1.5 psi. Often as low as .3 psi. Once I saw .1 psi. Of course, my pressure sensor could be off, but with the electric boost pump on before startup, I can see 6-7 psi, and when the engine pump dips, if I turn it on, I can see 5-6 psi. All of this on the ground.)
