This thread title once had some information on link-belts like Accu-link, but multiple searches does not pull it up. Can anyone point the way to sizing a link belt to replace (temporarily) a Dayco Top Cog 15355?
Merrill
The last three digits are the belts diameter in millimeters. Most belts have this number in them somewhere, usually the last three digits. You want a 1/2" wide link belt. They come in 3/8, 1/2 and 5/8. Be sure you have enough travel in the alt bracket, as most link belts are adjusted in increments greater than 3/4"
Larry
Larry
BTW, here's a good document on assembling the accu-link belt (Harbor Freight sells a 1/2" one for $35 or so):
https://megadynegroup.com/files/resources/attachments/md_broc_acculink_web_am_en.pdf
Installed direction appears to matter. It looks like the tab points away from running direction.
I have a pretty new (63 hours) Lycoming IO390 on my RV14A and want to pack a Power-twist belt for a cross country trip I'm planning in May. I see 3/8' and 1/2" in various treads. Anyone know the right width belt to get? Is Amazon $31.99 an okay vendor or are their different quality Power-twist models?Or just change your belt occasionally (suggest somewhere around 5-7 years) and don't worry about needing a spare
3/8 worked forI have a pretty new (63 hours) Lycoming IO390 on my RV14A and want to pack a Power-twist belt for a cross country trip I'm planning in May. I see 3/8' and 1/2" in various treads. Anyone know the right width belt to get? Is Amazon $31.99 an okay vendor or are their different quality Power-twist models?
