jliltd
I started a condition inspection on my RV-8 with IO-360. When I removed the bottom spark plug from #3 I had about a teaspoon full oil come out, and appeared to be cut by a bit of avgas so it was more "fluidish". Prior to the plug removal I did a compression check on #3 using the upper spark plug hole for the compression tester. It came in at 78/80. This was a test with engine hot after a little more than an hour flight.
This engine has 415 hrs TTSNEW and170 hours on a Barrett major with 170 hours on brand new Superior through-hardened steel cylinders.
Later today I will re-run a cold compression check on the cylinder.
I got my borescope camera and looked inside and found evidence of oil. In fact there is a a wet creek of it along the bottom of the cylinder wall heading for the bottom spark plug hole. The drain path that leaked out of the hole when I removed the spark plug. The edge of the piston is shiny wet with oil. See photos. Ignore the date stamp as my camera wasn't set.
I see mention of the cylinder solvent rinse process that can help loosen up stuck rings and get the oil control ring back to working properly. Would this cylinder be a good candidate for the solvent flush process as presented by Aircraft Specialties Lubricants and SAVVY?
